Tuning after headers?
Old Sep 3, 2003 | 09:20 PM
JS99Z's Avatar
Would there be any gains by getting a tune after a header install on a 99Z.
Old Sep 3, 2003 | 09:25 PM
ULTIMTEORANGESS's Avatar
yes,your afr will be affected so youll need tuning anyway.
Old Sep 3, 2003 | 09:30 PM
JS99Z's Avatar
Afr?
Old Sep 3, 2003 | 09:36 PM
air fuel ratio. any time you add a mod that affects it youll to tune your car to get maximum power out of it.
Old Sep 3, 2003 | 09:39 PM
JS99Z's Avatar
air fuel ratio. Duh! I should have known that!
Old Sep 4, 2003 | 10:47 AM
SunsetWS6's Avatar
Adding LT headers will change your a/f ratio but you don't need tuning by a long stretch. I wouldn't spend the $400-$500 to get it dyno tuned until you do internal mods like cam, heads/cam, etc. If all you're ever going to do is headers then ok but it's not needed at all & seems like a waste to me on just a basic bolt on car.
Old Sep 4, 2003 | 12:43 PM
96SFLZ's Avatar
Agreed...a tune won't hurt but it's definitely not necessary (90% of the time). If you're running really rich and are not planning any internal mods in the near future, then I'd say go ahead and get it tuned. If not, either don't get it tuned or wait until after you get the other mods done.
Old Sep 4, 2003 | 11:26 PM
00Hawk#140's Avatar
I have a question on this subject. My car seems to run well after LT install , and I have no tuning. Would it be helpful to run the Hypertech power tuning in the car ?? I have never run it, just use it to fix the speedo. I guess I would need to take the GMS maf off if I put the tuning in. ??
sorry to jump your topic.
Tim
Old Sep 5, 2003 | 07:49 AM
nikkev's Avatar
I installed headers and off-road pipe and I started running waaaaaay rich.I went from 27mpg on road trips to 22mpg going to the same destination.Also,where are you guys getting your numbers? They only charge $300 to dyno tune with LS1 edit around here.Also,you can do more than just get a tune:
-Firm up shifts
-Remove EGR
-Adjust timing
-Adjust AFR
-Remove A.I.R.
-Remove the requirements for O2 sensors in the rear with no cats
Old Sep 5, 2003 | 10:59 AM
SunsetWS6's Avatar
00Hawk#140 don't use your hypertech to "tune" because it's junk & doesn't tune. If you need to recalibrate your speedo fine, but otherwise it's a waste.
nikkev you're a rare exception. After I got LT's my gas mileage went up. So in your case it was beneficial but for 90% + it's not until major mods are added. As far as price it all depends where you live but a $400-$500 dyno tune is pretty standard. It's a hell of a lot cheaper to live in SC than CA.
Old Sep 5, 2003 | 12:23 PM
nikkev's Avatar
And we have no emissions laws either! The bad part is,I haven't got the tuning done yet.There is a guy coming down to a shop 1 hour away to do it over a weekend.So I have to wait for him to come down I think I am the only LS1 that I have heard of that slows down with mods
Old Sep 5, 2003 | 01:00 PM
petegz28's Avatar
I have not tuned since I put my LT's on and everything seems fine. I did remove my Hypertech tuning though.
Old Sep 5, 2003 | 06:07 PM
SSpdDmon's Avatar
So, does deleting your cats and running 02 sims affect your AFR??? I plan on doing that mod this December and was hoping it's not going to do much other than get me 10 more hp & a funky exhaust smell.
HarleyZ28
Oct 5, 2015 06:23 AM
thenewkid
Apr 12, 2015 07:42 PM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
Cam's maro
Jan 30, 2015 09:21 PM
k1996z28
Jan 21, 2015 07:22 AM
