air cleaner height?
Old Jul 18, 2002 | 11:02 PM
Timberwolf's Avatar
Post air cleaner height?
Ho tall of an air cleaner can I get under a stock, non cowl hood? Engine is 396 with a carter 4 barrel.
Old Jul 19, 2002 | 08:31 PM
BluEyes's Avatar
Post
what intake?
Old Jul 19, 2002 | 08:40 PM
1KWIK69's Avatar
Post
also what body style. Camaro 1st gen. 2nd gen?
Steve
69 Camaro 355ci, Dart Pro-1's, Flowed by CFM. Solid Roller 6" rods 13.2-1 Comp Turbo350 Trans 4700 stall.4:88 gears 29" Slicks or MH RaceMasters on the street
Old Jul 19, 2002 | 11:35 PM
Timberwolf's Avatar
Post
oops, I forgot to mention that. Stock intake, 1st gen.
I picked up a 10" round by 2" tall Edelbrock air cleaner housing today, but haven't put it on yet.
I see there's not much clearance though hate to have to go to one of those twin side mounted air cleaners for $300. Guess maybe the cowl hood will have to come a little sooner
Old Jul 21, 2002 | 07:40 PM
BluEyes's Avatar
Post
one thing you can try is putting some clay ontop of things and slowly close the hood - that'll tell you exactly how much space you have. I'd check at the front edge of the aircleaner - hoo clearance should be tightest there.
if you have a tight fit, you can always pick up a drop-base aircleaner - that'll gain you an inch or two depending on who makes it...
Be sure you have clearance between the choke horn (if it's still there) and the top of the aircleaner though.
Fatdog2
Feb 13, 2015 08:19 PM
SmokinZ28lt1
Feb 5, 2015 04:33 AM
95chwagon
Jan 13, 2015 09:19 PM
Collector Car
Jan 5, 2015 10:58 AM
stanghunter211
Aug 29, 2002 03:04 AM
