Car doesn't properly drop down to idle from a rev
Old Sep 1, 2003 | 04:46 PM
trax's Avatar
Question Car doesn't properly drop down to idle from a rev
I just replaced my bad roller rocker and readjusted all valves to zero lash. Started the car up, drives great, no hesitation or anything, no clacking, nothin'...
However, on occasion (not all the time) when I slow down to a stop and pop the car in neutral instead of downshifting, sometimes the RPM's will just kind of float at 1500 for a second or two and then drop back to a normal idle of ~900-1000 RPM. The car won't do it when just revving in neutral.
Is this a valvetrain issue?
Old Sep 1, 2003 | 05:05 PM
Lyle A's Avatar
My car does that sometimes on a stock engine and M6. I think it's a sensor (control) issue. What exactly, I'm not sure.
Old Sep 1, 2003 | 05:26 PM
Hyperspeed97z28's Avatar
Mine will do that sometimes as well... maybe the IAC ??
Old Sep 1, 2003 | 05:27 PM
Lyle A's Avatar
I replaced mine when I cleaned the TB and it still does it.
Old Sep 1, 2003 | 06:08 PM
Transamdriver's Avatar
It is suppose to do that so you have vaccum when braking.
Old Sep 1, 2003 | 06:32 PM
steelheart's Avatar
Re: Car doesn't properly drop down to idle from a rev
my car did the exact same thing, replaced the IAC and problem was solved,
calaban
May 18, 2020 06:43 PM
Britbilly
Jan 7, 2015 08:49 PM
pete53
Dec 9, 2014 07:31 AM
jayblev95
Dec 1, 2014 06:55 AM
USAirman93
Nov 24, 2014 03:37 PM
