Master Cylinder Problem
Old Sep 1, 2003 | 04:20 PM
incarnus's Avatar
I'm in the process of doing a 4L60E to T56 conversion, and I've discovered that my master cylinder is cracked. I dunno if I did it or it was like that when I got it (I bought a "kit" from Speed Automotive) but in any case I need to replace it.
So my question is, should I just get another stock one, or get the McLeod adjustable cylinder?
Also, does anyone have the part number for the GM cylinder?
It looks like the master, slave, and reservoir are all one piece, but I'm guessing from what I've read so far that you can take them apart. Is this so?
Thanks!
Old Sep 1, 2003 | 07:35 PM
iniviate's Avatar
you can have my stock clutch master if you want....
i'm local
email me at sprayed95ta@aol.com or iniviate on AIM if you want it.
later
Old Sep 1, 2003 | 10:16 PM
Can be taken apart, but GM sells the whole thing as a unit, not separately.
Old Sep 2, 2003 | 09:40 AM
incarnus's Avatar
i'm local
later
Sweet, sending you email.
Old Sep 2, 2003 | 01:01 PM
iniviate's Avatar
i didn't get an email.... so i sent you a PM with my phone number.
Old Sep 2, 2003 | 02:09 PM
rlax31's Avatar
CAUTION
I just finished my swap, and the stock master cylinder rod didn't seem to extend far enough to fit on the pedal correctly. I currently have it rigged up on the pedal incorrectly (so that the rod gets pushed in some-what correctly) untill I can get an adjustable one. Might want to check to make sure it lines up correctly before you buy the stock, fixed one. Anyone want to sell me an adjustable??? I'm looking for one so that I can shift smoothly
Ringmaster72
Mar 19, 2015 03:32 PM
BPS
9
Mar 5, 2015 10:51 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
siguy
Nov 27, 2014 10:07 AM
