3800 MAF Spacer?
Old Aug 30, 2003 | 11:07 PM
RCJim's Avatar
3800 MAF Spacer?
I keep reading about the 3800 V6 guys putting spacers behind their MAF's What does this do and where can I get one for my 96?
Old Sep 2, 2003 | 04:36 AM
morb|d's Avatar
if you're talking about a spacer, then you probably mean the trottle body spacer. its used to insolate the throttle body from the intake manifold. the idea is that if the throttle body is cooler, then the air has less time to warm up after its sucked in as it travels through the air cleaner to the trottle body, then the manifold then to the cylinders past the valves. cooler air, means denser air. denser air means there is more of it being sucked in which in turn means more power.
i don't personally know how effective the TB spacer is at doing what its billed to do tho.
the MAF is a sensor at the mouth of the throttle body. there are no spacers for it, but there's a honeycomb screen right in front of it. some people remove those because they reduce the air flow. i removed mine and i didn't feel any difference, so i put it back on.
Double aught
Oct 2, 2015 11:29 PM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
