Water in Oil......
Old Aug 30, 2003 | 03:06 PM
RacerTim's Avatar
Water in Oil......
Ok so today I went and drained the oil like everyone said, the oil had plenty of little bubbles in it so now I'm pretty sure that it is the head gasket. Question is... how can I be sure that it is the head gasket and that the block is not cracked? When I first changed the water pump I thought I saw water leaking from 2 places, one being the pump, and one being the bottom of the front case, by the oil pan. There was no trail from the leading to the water dripping from the front case. So is there a way I can check it, or do I just have to change the head gasket and go from there? I'm tempted to just rebuild the engine........
Old Aug 30, 2003 | 03:28 PM
TreySpeed's Avatar
On permanent vacation
99/100 its head gasket.
A cracked block would probobly create a lot of noise.
I wouldn't worry about it. just get your heads milled before you throw them back on.
Old Aug 30, 2003 | 03:30 PM
FastZinTennessee's Avatar
99.9% - headgasket
00.1% - cracked block or head
Pull heads off and inspect headgaskets. With the block being cast iron, it would be extremely hard to crack it. The heads being aluminum are more prone to cracking, but it's still quite unlikely.
John
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
colts0455
Sep 27, 2015 01:07 PM
