Problems with andew's aldl converter
Old Aug 29, 2003 | 11:12 PM
Highlander's Avatar
I am having problems with andrews ALDL converter or cable...
I cannot connect read using datamaster nor program or read using tunercat...
I used the ALDL test 2.0 from datamaster and it fails all tests (the converter is disconnected from vehicle but connected to laptop)
When I press the test com on the datamaster it shows... Incorrect message received from pcm or sometimes PCM not detected message, but gives an OK on the converter...
Any thoughts? ideas?
I haven't been able to get ahold of andrew, he seems an extreemely busy man...
I can read using my LT1 Scanmaster and I can read using an OTC automotive scanner (similar to tech 2). I do have a switch on the scanmaster so it doesn't interfere...
LMK any thoughts or ideas.. THanks
Old Sep 1, 2003 | 01:26 PM
97Z-M6's Avatar
mine did that and i had to change the com port settings.
Old Sep 1, 2003 | 05:27 PM
Highlander's Avatar
What settings?? i would love to know.. this was working one day and stopped the next.. soLet me know
WildRidez
Feb 23, 2015 07:24 PM
StansZ28
Feb 19, 2015 07:39 AM
ChrisFrez
Feb 15, 2015 07:49 AM
edxiel
Jan 24, 2015 07:40 PM
joe777107
Dec 1, 2014 09:32 AM
