Funky Moaning Noise
Old Aug 29, 2003 | 07:46 PM
Flat_Tire_'s Avatar
Funky Moaning Noise
My z28 makes this weird noise turning, faint during left turns and loud turing tight right turns. My mechanic drove it around, found the noise I was describing, checked out the suspension and couldn't find anything.. they're pretty sure it's coming from the differential .. You guys know what it could be?
Hard to describe the noise sounds almost like a rubbing/moaning noise.
Read this thread ... http://web.camaross.com/forums/showt...t=differential
sounds just like my problem but my mechanic changes out my fluids on a regular basis.
Old Aug 29, 2003 | 07:52 PM
KwikistZ's Avatar
This is what I think it is, there are two excessivly large hampsters in your trunk. Now, they are 'doing it'. The reason that the noise is louder when you turn this way and that is because the male hampster is on the right side, and the female on the left. When you turn right its louder cause the male is forced upon the female which makes 'it' go in deeper and his front legs scrape against the hampster bewbies. Hope that helps!
Old Aug 29, 2003 | 07:59 PM
Flat_Tire_'s Avatar
Talking
I'll mention it to my mechanic
Old Aug 29, 2003 | 09:20 PM
Omega9's Avatar
Are you sure there isn't a HOT chick getting off in your trunk? Better check!!
Old Aug 30, 2003 | 01:42 AM
AL SS590 M6's Avatar
Moderator
Front wheel bearings.
Old Aug 30, 2003 | 11:20 PM
Akshay's Avatar
Check if you have enough powersteering fluid.
Akshay
Old Aug 30, 2003 | 11:25 PM
95GRNZ's Avatar
Thumbs up
I'll second that.
Old Aug 31, 2003 | 10:36 PM
chevyzman1998's Avatar
its axle bearings
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
colts0455
13
Aug 7, 2015 09:15 PM
GT what?
Jul 14, 2015 10:17 PM
colts0455
Jul 7, 2015 07:19 PM
