Completely wrong fuel injector in my Camaro!!
Old Aug 28, 2003 | 09:11 AM
Brian2002SS's Avatar
Exclamation Completely wrong fuel injector in my Camaro!!
Don’t know how this happened but I have a wrong fuel injector for Piston #1. It is misfiring naturally and has tremendous drag on start up and when air is at max AC. I want to know how to check for myself if the other pistons have the proper fuel injectors in them because I do not trust the local dealership to do this even after I have repeatedly asked them to do this. I get the standard “well, we automatically check the other ones anyway.” So if you can tell me how to check that I have the proper fuel injectors installed from the factory please let me know. Camaro 2002 SS. Thank you for your help!
Old Aug 28, 2003 | 10:21 AM
V6toZ28's Avatar
Aren't the fuel injected color coded??? ... each size and type has it's own color???
Old Aug 28, 2003 | 02:11 PM
colored fuel injectors?
If this is so, I don't know what i am looking for. should all the injectors have the same color or are some one color and others another color? I am in the dark in this arena so if you have the time to enlighten me I appreciate it. This is my first sports car so I am learning as I go here.
Old Aug 28, 2003 | 10:21 PM
Beast96Z's Avatar
The ford/SVO aftermarket injectors are color coated. I don't think GM color coats there injectors.
AdsoYo
May 2, 2018 03:21 AM
CARiD
Dec 26, 2014 04:20 AM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
Burn_Out
Aug 18, 2002 08:49 AM
