Twisted driveshaft slipjoint splines?
Old Aug 25, 2003 | 11:55 AM
Grover's Avatar
Has anyone every twisted the splines on the driveshaft slipjoint? I was removing my Denny's nitrous ready driveshaft yesterday so I can pull the tranny and had a very hard time getting it out. Once it finally came out I looked in the slip yoke and about 3/4 of the way down the splines are shifted just enough so it isn't a straight shot all the way down to the bottom.
I guess I will have to send it back to Denny's.
Old Aug 25, 2003 | 11:59 AM
Nostang 96z's Avatar
Yeah you will need a new yoke. When I broke my output shaft on my car my output shaft was stuck in the Denny's slip yoke and would not come out at all. You might want to upgrade to the billet yoke. BTW Denny's will not cover the yoke for the warranty only the driveshaft itself...just a heads up.
Later
Matt
Old Aug 25, 2003 | 09:20 PM
Grover's Avatar
Thanks Matt, that's kind of what I figured. BTW I am having some problems with the street twin I bought from you. I had it installed back in march and it worked fine, then all of a sudden it wouldn't fully disengage. So I then adjusted the master cylinder to get it to fully disengage and now the engagement point is at the top of the pedal stroke and I am getting a terrible ticking noise. I am in the process of pulling the tranny to see what is going on with the clutch.
Old Aug 25, 2003 | 09:40 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
the ticking noise is probably the fork hitting the pressure plate from too much throw!
Old Aug 26, 2003 | 06:05 AM
Grover's Avatar
Okay Jordan I'll readjust that. Do you have any idea why the clutch wouldn't fully disengage?
Old Aug 26, 2003 | 06:10 AM
I would think that the only reason that the clutch is not fully disengaging is that the throwout bearing is not being pulled back enough to disengage the clutch. That is weird that the clutch worked for that long and just all of a sudden started having disengagement problems. It has got to be in the throwout bearing, the clutch fork, or the steel mounting tab of the clutch fork (was this machined down too much?). Just giving you some ideas.
Matt
RUENUF
Mar 13, 2016 03:37 PM
CARiD
Sep 30, 2015 05:44 AM
Aaront810
Sep 11, 2015 11:24 AM
Daluchman1974
Sep 11, 2015 06:12 AM
realistyc
Jul 28, 2015 07:32 PM
