Help, my 'bird is spewing oil badly
Old Aug 26, 2002 | 01:21 AM
bigdave8301's Avatar
Post Help, my 'bird is spewing oil badly
Hey, I've got an '89 Formula, 5.7L 350, and all of the oil is literally "falling out" of my car. I know that term can't really be applied, but it comes the closest to describing it. I cleaned my plenum the other day and took it out and hammered on it a lil, but when I got home I noticed my car wasn't running worth a crap and shortly after that, smoke started rolling out from under the hood. I checked the oil and it was barely on the stick, and you could trace where I had been because there was a nasty 2-foot-wide trail of oil all down the road. It was all over the belly of the car, but mostly on the tranny and oil pans and my bell housing. I've heard that it could be my rear main seal, but there's a puddle of oil laying on my intake, which would eliminate that possibility, so what else could it be? Could the sending unit possibly spray it out that fast and heavy? Please, I'd appreciate any replies.
Old Aug 26, 2002 | 01:30 AM
smallwood's Avatar
Post
It sounds like your intake was not properly sealed when you reinstalled it. If your car develops a nasty leak or other problem right after you work on it, always go back and check the area you were working on.
Little red light on the highway; big green light on the speedway, hey, hey, hey!
Old Aug 26, 2002 | 01:55 PM
RedIrocZ-28's Avatar
Post
So you only took the plenum off eh? Not the lower base manifold? Ummm..... Did you forget to use the gaskets??? There really aren't many things that you could have done wrong. Pinpoint the exact location of the leak.
Old Aug 26, 2002 | 02:26 PM
Bristol's Avatar
Post
If you took the lower intake off I bet the gasket between it and the block slipped out. If you used the rubber one I bet thats the problem. I used a bead of silicone at the front and the rear.
Old Aug 26, 2002 | 06:11 PM
Question
I'll have to check the gaskets then. Would it make it spew it that heavily though? My car was empty in no time.
Old Aug 27, 2002 | 09:23 AM
firechicken_3's Avatar
Post
you didn't bottom it out or nothin did ya?
in a manner that may put an extra drain hole in the oil pan? make sure the plug is tight too, they can work them selves loose on there own sometimes
HectorM52
Jul 30, 2017 11:46 AM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
ad356
Apr 11, 2015 08:49 AM
captcorvette
Mar 7, 2015 12:37 PM
