launching with an M6
Old Aug 22, 2003 | 09:23 PM
98whiteZ28's Avatar
So i'm goin to the track for the first time next week, i still have stock gears in my 99 SS and i was wondering on take off how should i do it.Like whats the tricks and what not?? thanx
Old Aug 22, 2003 | 10:04 PM
Geezer powered's Avatar
rev to 4000 grand and slip the clutch off the line.Then pedal to the metal.Not good for your clutch but good for et
Old Aug 23, 2003 | 12:07 AM
LT-14me's Avatar
Well i was told to rev to about 1500-2000 u dont want to go too high cause that will just cause ALOT of wheel spin.
Old Aug 27, 2003 | 01:27 AM
mebanditws6's Avatar
Unless you have $ for new clutches on a regular basis, don't slip it even though it does work. Try feathering it off the line from idle. It's a trial and error thing but you'll get it.
Jason
Old Aug 27, 2003 | 08:00 AM
SheDevlLS1's Avatar
4k+streeties=MASSIVE wheel spin.
On streeties, try 1500 and slip it just a hair-dumping will also cause too much spin, plus the stock clutch and rear dont like dumpage much . I've got 23k miles on mine and ohh, about 75 passes on DR's while slipping the clutch, and it's holding up fine. Just dont over-slip and smoke it and you'll be aight.
On DR's, I do 3500+/- and slip the clutch...it's made for a few low 1.9 60's so far.
Also- carry it on up to 6k (or as close as you can get to it) before you shift...when I first got my car I was too chicken to go over 5500 when racing, but you wouldnt believe what a difference the extra 500 rpms has made.
Old Aug 27, 2003 | 10:45 AM
Eric @ DMS's Avatar
Depends on your tires. If you have Nittos or equivalent..1500-2000 will cause you to seriously bog. If you have street tires...4000 will just spin. Use those numbers and find the happy medium. It does take practice. Rarely will you see a 1st timer do a flawless launch. Slipping the clutch will greatly reduce its life but if done right can net good 60ft times. Good luck and remember....you'll get the hang of it
Old Aug 27, 2003 | 05:29 PM
Robbie's Avatar
My best experience is revving to 3k or so and easin the clutch out. Gets you moving off the line a little better. At least for me. When I did 1500-2k launches I was feeling like it was bogging. You want to get it moving first thing. Its not good for your clutch but as long as you dont hot lap it it will be fine. If you were to directly ask me I would say hold it at 3k and slip the clutch slowly then WOT. If that dont work then just adjust the rpms your launching at to lower like 2k or 2500.
Old Aug 27, 2003 | 07:03 PM
Greed4Speed's Avatar
Caution...install subframe connectors prior to sticky tires.
Old Aug 27, 2003 | 07:40 PM
Robbie's Avatar
Why? Wheelhop?
Old Aug 27, 2003 | 07:41 PM
VentsWoker's Avatar
well, get used to high 1.9's and for the most part 2.2+ 60's with the M6, unless you're ready to get a clutch, a rear, and some slicks. they generally dont like stoppie racin in stock form.
now, get ya those parts along with some sub's and suspension stuff, start launchin @ 5.5k and get ready to cut low 1.5 60's w/ some minor motor work.
Old Aug 27, 2003 | 10:28 PM
SLOW_SS
Guest
Posts: n/a
Originally posted by Robbie
Why? Wheelhop?
To eliminate Wheelhop, LCA will do the trick. SFC helps little but LCA will plant wheels on the ground.
Old Aug 27, 2003 | 10:39 PM
Eric @ DMS's Avatar
LCAs coupled with brackets will do even a better job
Old Aug 27, 2003 | 10:41 PM
Eric @ DMS's Avatar
Why? Wheelhop?
Your F-body will experience some serious flexing when launching off the line. The constant flexing will cause squeeks and rattles in your car. Once that happens you'll hate it. SFCs will allow your chasis to be a lot more rigid and stops the constant flexing. You can definitely feel the difference.
Daluchman1974
Sep 11, 2015 06:12 AM
Critter
Jul 13, 2015 05:51 PM
Injuneer
May 15, 2015 08:45 AM
mark0006
Dec 25, 2014 09:50 PM
