LS1/LS6 into a 93 f-body?
Old Aug 22, 2003 | 12:16 PM
Carlos01SS's Avatar
This is just a thought, but a serious one nonetheless, I am considering this, I have thought of what needs to be changed, please let me know if there are other things that I need to consider:
Different motor mounts.
Different hood, I know that the LS1 motor sits higher than the LT1's.
Different computer, and new bolt-ons, everything required for an LS1.
Different wiring harness.
Change front springs & shocks.
Here's my questions, is the front end suspension, ie. A-arms, K-member the same as the LT1's?
How's about the tranny? Will I have to purchase a new 6-speed? Is the Hydraulic clutch assembly the same or will have to change that as well? If I have to get a new tranny, will new tranny mounts be required, or do they use the same ones?
Old Aug 22, 2003 | 03:47 PM
You might want to do a search on LT1 Tech... I know I've answered this one a couple times, or at least contributed to the thread.
LS1 K-member is different.
LS1 T56 is different - longer input shaft.
LS1 clutch slave/master is different - slave sits concentricly around the tranny input shaft
LS1 clutch is different - its a conventional "pusher"
LS1 radiator is different - its "conventional" flow
LS1 radiator support structure is different
LS1 needs a higher fuel pressure - 58psi
LS1 has a different fuel supply strategy - dead-ended supply, with pressure control/recycle from the fuel filter.
Moving to "LT1 Tech".......
Old Aug 22, 2003 | 04:28 PM
RedPhenx's Avatar
youd be better off in the long run putting an lt1 (if its a v6) or building the lt1 you have, than trying to put an ls1 in the car.
Old Aug 22, 2003 | 05:49 PM
Cmr0z28's Avatar
its a z28, therefore its an LT1
Old Aug 22, 2003 | 06:25 PM
AndyB's Avatar
The money would be better spend building up the lt1
Old Aug 22, 2003 | 11:44 PM
Got-LT1's Avatar
Just work the LT1, putting an ls1 in is not worth the hassle.
Old Aug 23, 2003 | 12:52 AM
Antz97ZNJ's Avatar
for what it would cost build your engine for FI and put a blower on you'll never look back
G-BODYT56
Jan 14, 2022 11:14 PM
bunker
Jan 30, 2016 08:09 PM
n2oblkz
Oct 12, 2015 01:53 AM
bunker
Aug 1, 2015 10:10 PM
