Question on swapping out waterpump
Old Aug 21, 2003 | 09:00 AM
Gripenfelter's Avatar
Nothing wrong with my waterpump besides the fact that I have 100K miles on the stock original.
Would draining the rad be enough or would I still need to drain the block of coolant?
On my dad's Buick Regal we just tightened down the bolts to what felt snug enough and its held up fine with no problems.
Is it ok to do the same or should I follow the torque specs to the point?
Do I have to remove the opti?
Old Aug 21, 2003 | 09:06 AM
Dave Feerst's Avatar
I would get the torque specs, better safe then sorry.
I would also drain the block too, less chance of spilling it on the opti and it only takes 30 seconds.
The opti doesn't have to come off.
Old Aug 21, 2003 | 10:13 AM
Where do you drain the block from?
The knock sensor?
Old Aug 21, 2003 | 10:20 AM
turbo_Z's Avatar
the knock sensor acts as a plug so there is also a true plug in the same location on the other side of the block. just draining the rad wont get all the coolant out that youll need out if you want the opti to stay dry in the process. ive had mine off several times and just snugged up the bolts.. didnt worry about the specs and never had a problem.
Old Aug 21, 2003 | 11:54 AM
bradpreece95z28's Avatar
I just snugged them down real good, never had a problem either.
Old Aug 21, 2003 | 12:35 PM
x7x7's Avatar
I've replaced my waterpump once and pulled it another time to replace the opti. Just draining the Rad is fine. There won't be too much that spills out of the block and hoses, just have a rag to soak it all up. I didn't follow the torque specs just snugged em up good.
Old Aug 21, 2003 | 02:52 PM
Ok thanx guys.
Old Aug 21, 2003 | 03:02 PM
spend another 30 seconds and take the precautions or youll be acking for jason cromers # for an opti real soon.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Sergio
Jan 27, 2016 04:27 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
cmdeshon
Jan 4, 2015 11:15 AM
pologreen97z
Dec 2, 2014 10:42 AM
