what do you think I will run with ET streets??
Old Aug 21, 2003 | 01:30 AM
JeremyKweens's Avatar
15 inch ET streets on old camaro rims on my 1995 z28 with the mods in the sig...
Old Aug 21, 2003 | 01:35 AM
QCKZ28's Avatar
13.6 at 100mph
Old Aug 21, 2003 | 01:37 AM
atljar's Avatar
Ya about that, are you going to launch it ***** to the walls? I can see 13.4s on a 1.8 60'
Old Aug 21, 2003 | 01:41 AM
ive never ever launched with ET streets...how is the best way to launch?? 3000??
Old Aug 21, 2003 | 01:53 AM
atljar's Avatar
Heat them up, and drop the clutch off the rev limiter. Thats ***** to the wall, also the best way to explode the 7.5 rear you are working with. I was doing those launches with heated drag radials and it held. My rear end also whined a little after that track day, lol.
Old Aug 21, 2003 | 08:28 AM
Sweetred95ta's Avatar
How big are those slicks? I tried putting 26 inch slicks on my car and they were mounted on 3rd gen z28 rims (rear). They definitely didnt look bad, but they rubbed. I'd watch out for that. But your et will depend on how hard you want to launch. The better the 60 ft, the better the et. 13.5 @103 id say with a good (1.8-9) 60 ft. Good luck.
Benji
Old Aug 21, 2003 | 03:18 PM
the tires are 26 x 10.5s mounted on 15 inch Z28 rims...the old old ones. They fit not to bad actualy.
Old Aug 21, 2003 | 03:51 PM
TedH's Avatar
13.5-13.6 at 100-101 if you can shift. 13.8 is you are decent (not great), and 13.9-14.1's if you granny shift of the weather sucks.
Old Aug 21, 2003 | 07:06 PM
I know the slicks look good, they did on my car too. But I noticed some rubbage when I was driving it, because the rim actually stuck out farther than the quarter panel. I was also running 11.50's though. Could just be me. Good luck and dont break anything.
Benji
Old Aug 21, 2003 | 08:39 PM
97SS0594's Avatar
ill giva another vote for 13.60@100 or 101
Old Aug 21, 2003 | 09:09 PM
Jake77444's Avatar
Shouldn't he be trapping 104-105? why are people saying 100-101, ive seen people land that stock he has headers/exhaust/cai and et streets id say 13.3-13.4@104-105
Old Aug 22, 2003 | 09:22 AM
HardcoreRM125's Avatar
Id say 13.5-13.6 @ 103ish ...
Theyre all saying lower trap speeds cause of the sticky tires, they'll lower your time but for some reason you also get lower MPH with them as well
Old Aug 22, 2003 | 10:05 AM
94formulabz's Avatar
First of all, what does your car run now? is it strong and tuned up?
I'm gonna assume that you can shift, decent air up there in oh canada and that you let your car cool off a lil first so I say your going to run a
13.2 at 104
In other words your car should be easily capable of that.
Your 60' may not get much better than 1.9 flat depending on track prep and because of the stock clutch's ability to hook from a high rpm drop.
In 90° weather I pulled 13.2 at 106 with near same mods and a 1.95 60'. I do have 3.73s, tuning, and 1.3/4" primarys which all help a lil.
Let us know how it turns out though
Old Aug 22, 2003 | 01:25 PM
x7x7's Avatar
I see a broken 7.5 in your near future, if you launch hard.
Old Aug 22, 2003 | 04:46 PM
If you have the money saved up for a rear end ,possibly more if you dont do the work yourself ... Then beat the living **** out of the stock rear till it dies ... Or take it out and sell it now for a few bucks on Ebay and get a good one before you loose the opportunity of having a funtional rear to sell ...
If you dont have the money for it , launch easy, then give it your all after the launch ... No sense in burning up a rear end for a tenth or two
