bad odor
Old Aug 20, 2003 | 07:20 PM
polcat1p's Avatar
bad odor
I have a bad odor coming in the car while driving.It almost smells like unburnt gas ,oil,or coolant.I can't really describe it but it makes my eyes water. The guy who owned it before me gutted the cat,but it does not smell like rotton eggs. Any suggestions. Also my coolant,and oil levels dont drop,and no signs of coolant in my oil,plus i changed the opti,plugs,wires,fuel filter.Car has 116k.Thanks
Old Aug 20, 2003 | 08:28 PM
Lyle A's Avatar
None of those three items smell the same when they are burning. Which is it? Maybe it's the gas you're buying.
Old Aug 20, 2003 | 08:33 PM
mirroredfire2's Avatar
go to the back of your car and smell the exhaust then u can at least mark one out if it don't smell like that..
Old Aug 20, 2003 | 08:35 PM
polcat1p's Avatar
bad odor
i use 87 pump gas . But after i change my oil the smell seems to go away for awhile.Could it a valve ,or a intake gasket.
Old Aug 20, 2003 | 08:37 PM
Lyle A's Avatar
Try switching to 91 octane or better. Does it smoke when you drive it or start it? Does it smell like it's coming from the exhaust or engine compartment?
Old Aug 20, 2003 | 08:40 PM
polcat1p's Avatar
bad odor
The exhaust from the tips smells bad also,and when i put my hand to it ,it feels like a slight mist.
Old Aug 20, 2003 | 08:41 PM
Lyle A's Avatar
See if you have oil running down the back of your engine and on the trans. My intake has a slight leak as do many other LT1's. But I hardly ever smell oil or see it on the ground.
Old Aug 20, 2003 | 08:44 PM
Lyle A's Avatar
I think it's just because you have no cat and you're burning too low octane fuel.
Old Aug 20, 2003 | 08:47 PM
polcat1p's Avatar
It only comes from the exhaust,but i dont know how it comes into the car. Isnt the car made to run on 87
Old Aug 20, 2003 | 10:59 PM
Lyle A's Avatar
No, High compression engines should run high octane fuel. Like I said, with a gutted cat your exhaust is going to smell different than if you had a cat that worked.
colts0455
13
Aug 7, 2015 09:15 PM
Jocofire1
Aug 7, 2015 03:16 PM
zajones
Jul 30, 2015 02:18 PM
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
