Water Pump
Old Aug 20, 2003 | 09:59 AM
ChrisUlrich's Avatar
Water Pump
Yo
If your Water Pump goes bad... what does that mean other than Water Pump going bad? L0L
What are some chain reactions that would occur from this crap? Because thats what happened to the car i'm about to look at, the Water Pump went bad and the car began to overheat.
Old Aug 20, 2003 | 10:41 AM
IDOXLR8's Avatar
When your waterpump goes bad it begins to leak coolant from the weep hole (located on the bottom of the waterpump). If the problem is not fixed quickly you run the chance of coolant entering the opti which will cause your car to misfire. If that happens then you will more than likely have to replace the opti with a new one.
Old Aug 20, 2003 | 10:45 AM
Yo
Well he said once the car started to overheat he pulled over and got it towed anyway, but anyone would say to the person they are trying to sell it to. L0L
When you say misfire, you mean slip right? Where you floor it and the rpms sky rocket while the acceleration is not?
Chris
HectorM52
Jul 30, 2017 11:46 AM
Biggiebound
Apr 21, 2015 11:28 PM
KYWes
Apr 15, 2015 07:28 PM
Blood type Z28
Apr 8, 2015 11:34 PM
pologreen97z
Dec 2, 2014 10:42 AM
