General Brake question?
Old Aug 19, 2003 | 05:32 PM
SNEAKY NEIL's Avatar
Is it bad to put on new rotors while still using the existing brake pads? Thanks.
Old Aug 19, 2003 | 06:12 PM
Metlhed54's Avatar
i wouldnt think so unless your pads are messed up in some way
Old Aug 19, 2003 | 06:58 PM
GCEZ28's Avatar
Why are you changing the rotor? If it is groove then you pads are grooved also. If is just warped, wait till your pads are need to be replaced before doing anything. It is generaly not a good idea to not change pads when replaceing rotors. the pads will be worn to the old rotors and you could end up with poor braking, faster wear or noise.
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Jan 18, 2015 08:05 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
Hurin
Dec 13, 2014 07:38 PM
