doing a water pump removal/install got a couple questions
Old Aug 16, 2003 | 10:02 PM
CamaroZBoy's Avatar
Okay first off does anyone have a step by step walk-me-through process of removing the water pump and then installing the new one. Im just swapping a stock replacement one, im not doing the electric ones or anything. Any tips or anything would be great.
Also, there is an o-ring on the spline shaft coming out of the engine, is that supposed to be replaced during the water pump change as well?
thank you
Cory
Old Aug 16, 2003 | 10:23 PM
Lyle A's Avatar
Here's a drawing that might help.http://csce.uark.edu/~jgbertr/rb/ci/water_pump.jpg
You should get yourself a good manual so you have it right at your fingertips. GM manuals are the best and can be obtained from www.helminc.com for a pricey $90. Definitely worth it though.
Old Aug 16, 2003 | 10:32 PM
madhatter's Avatar
or you can have this
Old Aug 16, 2003 | 10:33 PM
Lyle A's Avatar
That came up as a blank page for me.
Old Aug 16, 2003 | 10:35 PM
madhatter's Avatar
hmmm weird, works fine for me....
Old Aug 16, 2003 | 10:41 PM
Lyle A's Avatar
So what is it?
Old Aug 16, 2003 | 10:55 PM
EviLZ28's Avatar
Its the GM parts manual on CD. It gives a blow up on the engine as well as everything else on our cars. You can get them on ebay for like 3.00 bucks.
Old Aug 16, 2003 | 10:59 PM
Lyle A's Avatar
Yeah, I just figured that out. I can't open it on his link for some reason, but I can download it. It's in process. All 121 megs.
Old Aug 16, 2003 | 11:05 PM
Just remember it is a parts book and not a repair manual. Two different things.
Old Aug 16, 2003 | 11:08 PM
Lyle A's Avatar
Yes I know. I have a GM manual already and now for some reason I can't view that manual I just downloaded. Hmmm Go figure.
Old Aug 16, 2003 | 11:11 PM
It should work if you have the latest version of Acrobat Reader.
Old Aug 16, 2003 | 11:24 PM
Lyle A's Avatar
I just upgraded to version 6.0 probably while you were typing that response. Thanks, It works now. Nice to have all the part numbers. That's what's in the far right column right?
Old Aug 17, 2003 | 12:38 AM
Bud M's Avatar
My manual recommends changing it so I did. The new O ring can be damaged by pushing it onto the splines so use something to ease it onto the splines. I used the cone shaped cap off a bottle of gear lube.
Old Aug 17, 2003 | 12:46 AM
AsianSensation's Avatar
This is a good guide for changing a water pump. Just ignore the electric water pump part. It has good instructions for taking the water pump out.
http://ken.lowrance.com/Projects/CSI...mp/Default.htm
Old Aug 17, 2003 | 09:16 AM
Coop1's Avatar
Can you get the seal for the waterpump shaft at autozone or is that a dealer part? If it is a dealer part what is the part number? I am asking cause my waterpump is starting to barely weep. I need to change mine here soon.
