Can I move a car after the motor is dropped out the bottom?
Old Aug 16, 2003 | 04:05 PM
dkeers's Avatar
If I drop the motor out the bottom (with the wheels, suspension, etc.) how hard would it be to get the car on a trailer and take it somewhere? Do I need to worry about twisting the body since there is nothing holding it straight? Also, how much does the front of the car weigh with everything out? (I don't need a number but can say two people pick it up?)
Dustin
Old Aug 17, 2003 | 11:15 AM
dkeers's Avatar
Most people do drop it from the bottom right? I don't mind working on my car in the driveway but I'm not going to let it sit there for however long it takes me to rebuild the motor. Has anyone had to move their car?
Dustin
Old Aug 17, 2003 | 11:20 AM
Z95m6's Avatar
i moved mine around the driveway with a engine hoist after the motor was out but not on to a trailer. I have subframe connectors so there was no real body twist.
Old Aug 17, 2003 | 11:23 AM
EviLZ28's Avatar
I bought an old sub frame from my local boneyard for 40.00 bucks. I then welded some Large roller castors on the bottom of it then bolted it to the car. Now I can roll my Body of my car all around the driveway.
Old Aug 17, 2003 | 12:05 PM
iniviate's Avatar
i put a 4x4 board across where the k-member used to go..... jacked it up and rolled it around on the floor jack.
worked fine to back it up ~20' so it was outside and i could pressure wash the underside & engine bay.... but i wouldnt leave it like that, it's not very stable.
Old Aug 17, 2003 | 12:21 PM
augi's Avatar
I just do this to a friends car. Once the engine was out, we took it off the k member and put it in the engine stand and bolt the k member back in place. It takes like 10 minutes to bolt the k member in. We just made the bolts figer tight and push it out the door.
Old Aug 17, 2003 | 12:48 PM
Dave Feerst's Avatar
the last way would be the best way to do it, but you are talking an hour or 20 just to line it up and put the bolts in finger tight and another hour to un-do it when its time to install the motor...
LeftoverChinese
Jan 14, 2024 03:03 PM
97SSdude
Dec 31, 2014 07:43 PM
formula218
Dec 2, 2014 04:27 PM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
