I bet you haven't been asked this cam question...
Old Aug 15, 2003 | 07:25 PM
kevmor99's Avatar
What is a good cam to use with an LT1 in a truck. I don't want to loose too much low end power because I want to occasionally tow. Would a 112 or 114 LSA be better in this case? hotcam? A higher stall converter wouldn't work well with towing either, would it?
Old Aug 15, 2003 | 10:00 PM
kevmor99's Avatar
nobody?
Old Aug 15, 2003 | 10:53 PM
GreenZ28in503's Avatar
Crane makes a 210/224 that the Impy guys use... some guys on here running it as well.
Old Aug 15, 2003 | 10:57 PM
J's 82's Avatar
I'll add another peice to the puzzle and say 114 lsa is what you want..
Old Aug 15, 2003 | 10:59 PM
If you want to have low rpm torque for towing, you probably don't want to go with a low LSA cam.
Old Aug 15, 2003 | 11:02 PM
J's 82's Avatar
looking at thunder racing.. the comp cams 304 doesn't look too shabby.. good lift, duration isn't too steep, and on a 114 lsa..
alliance12364
Mar 6, 2015 04:39 PM
Lederman1976
Nov 30, 2014 05:21 AM
kizz
31
Sep 4, 2002 01:17 PM
HuJass
Jun 27, 2002 05:31 PM
