Anyone Know if a Snap-On OBD-I connector will work with Cable???
Old Aug 14, 2003 | 03:02 PM
ZPaul2Fresh8's Avatar
I got an OBD-I connector for use with a Snap-On Diagnostic scanner, it's labeled GM3 - ABS...
I havn't gotten my laptop yet so I was wondering if this connector would work? I already got the cable for the com port.
I'm pretty sure it should work since it's designed for communicating with GM OBD-I PCMs. The Snap-On scanner is primarily a read-only tool, but I have a 93 so I can't flash my PCM through the OBD-I port anyhow...Any thoughts would be appreciated.
Old Aug 14, 2003 | 03:11 PM
madwolf's Avatar
No, it will not work. You will need a converter box besides the connector and I'm sure the other end of the snap-on won't work with Andrew's box. You should contact him directly to see if he may be able to build you a box for your cable to cut the price some.
Parts Wanted
Mar 17, 2015 11:24 PM
edman
Jan 25, 2015 02:41 PM
squarehead
Jan 15, 2015 07:02 PM
cmdeshon
Jan 4, 2015 11:15 AM
Double aught
Parts Wanted
Nov 23, 2014 06:11 PM
