? 4,500 rpms max without SES light on
Old Jul 17, 2002 | 08:57 PM
68 RS's Avatar
Post ? 4,500 rpms max without SES light on
I hope you guys have some ideas for me.
This is what I have...
88' Formula Firebird 305 TPI / 5 spd.
Just did a tune up, plugs, wires, cap, rotor...Had intermittent codes 33, 34, 44, 45.
Car has a rebuilt motor w/ approx. 65,000 on motor. Exhaust was replaced with complete 3" from the Y-pipe to the mufflers and 2- 2 1/5" out the back. Bosch MAF (probably stock) nothing special that I could find on the rest of the car.
Here's my ? When the SES light is off the motor will not run above 4,500 rpm's. It will but there is no more to be had at that point and it sounds like it is running out of fuel and air. When the SES light is on from one of the codes mentioned above the cars will run right up and through 6,000 rpms and be pulling all the way through. (read no hesitation)
What are some possible solutions that I may be overlooking. The O2 sensor reads the right voltage at idle. This car isn't my hot rod but does a fine job on daily excursions and getting it to run tops would be greatly appreciated.
...Ron
Gtpguy
Jan 26, 2015 04:50 PM
edman
Jan 22, 2015 02:45 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
