nine inch bearings.
Old Aug 7, 2003 | 11:53 PM
klbjoc's Avatar
nine inch bearings.
I just bought a new Moser 9 inch off a guy and I have a question about the axle bearings.
Does the spacer get pressed on before the bearing gets pressed on? Also, how can you tell which side of the bearing is suppose to be facing out towards the wheel side of the axle.
I didn`t get any instructions and I have never messed with a 9 inch before.
Kevin
Old Aug 8, 2003 | 02:22 PM
klbjoc's Avatar
Is there a website that has info on nine inch rears? I can`t find any type of guide on them at all. All I need to know is how the stupid bearings go on!
Kevin
Old Aug 8, 2003 | 07:56 PM
IROCZZ3's Avatar
The bearing gets pressed on first, then the spacer. The 'spacer' is actually a 'lock' collar that prevents the bearing from sliding off.
If you ever have to change the bearing, the lock collar must be chiseled off, then press the bearing off the axle.
As for which way the bearing must face, I don't remember which way I put mine in. Do you have the O-ring style bearing? If I had to guess I'd put the side with the O-ring facing inward (toward the pumpkin). Maybe someone will chime in with a definite answer.
Old Aug 8, 2003 | 08:22 PM
klbjoc's Avatar
Thanks,
I already pressed it on, but I put the o-ring towards the wheel side. The bearing stuck out further on that side so I assumed that went up against the collar on the axle.
Kevin
Z Power
Sep 19, 2015 11:19 PM
rvonsternberg
Sep 14, 2015 11:58 AM
Daluchman1974
Sep 11, 2015 06:12 AM
zk06
Sep 9, 2015 11:39 AM
maverickmk
Sep 1, 2015 09:17 PM
