350 question
Old Aug 6, 2003 | 08:28 PM
FLIPPINZ28's Avatar
350 question
will the older model 350 engine fit in a 4th gen z28 like are the motor mounts in the same location or will i have to do some welding/cutting or an engine plate to put it in my car. if so i am going to wait to get it running when i finish my lt1 up thanks for any info
Old Aug 6, 2003 | 08:34 PM
94m5's Avatar
Your gonna have to modify the fuel lnes for a carbed engine, But I see your doing that anyway. If your planning on actually going to carburation, I would get an old running core and do all of your modifications with that. then build your badass and do your finishing touches with that. I am sure that the motor mounts will work. Is that a 6-speed or auto?
Old Aug 6, 2003 | 08:35 PM
RedPhenx's Avatar
motor mounts are same for lt1.. not sure about ls1 but i *think* they are different location... why are you going to put a gen 1 sb in your 4th gen? seems like a waste of time etc... also depending on year of engine... illegal
Old Aug 6, 2003 | 08:37 PM
94m5's Avatar
Yes LS1 mounts are different, But I don't think that the smog in Tennessee, so youll be fine. I can see why you would want to go with a gen1, theyre easier to get power from than an LT1. IF and WHEN you do this, I have a 4-bolt main 350 sitting in my garage that I'll trade for an LT1
Old Aug 6, 2003 | 08:38 PM
FLIPPINZ28's Avatar
it is an automatic i am just putting an older model in so i can drive the car and when my 4th gen lt1 is finished i will be putting it back into the car which i am going carb on it too. so the motor mounts are the same location?
Old Aug 6, 2003 | 08:40 PM
RedPhenx's Avatar
i just saw you have a 93. yes
Old Aug 6, 2003 | 08:41 PM
FLIPPINZ28's Avatar
hey 94m5 i already have the lt1 block sitting in my garage. is that 350 4 bolt main ever been machined or anything bored over if you know what year is that block from thanks
Old Aug 6, 2003 | 08:42 PM
FLIPPINZ28's Avatar
yeah its a 93
Old Aug 6, 2003 | 10:17 PM
The big problem is fitting the SBC distributor under the cowl. It can be done with a "pancake" style distibutor, and possibly alterations to the windshield wipers. You will also find it a bit hard to close the hood with most carb/manifold combos. Just hope you don't have to pull the distibutor out for any reason after the engine is in the car.
Old Aug 6, 2003 | 10:26 PM
FLIPPINZ28's Avatar
i have a big block hood so no clearance problem but it would be a b**** to do the distrubuter after in the car lets hope that will not be a problem though but will my power sterring hook up or not
Old Aug 7, 2003 | 11:47 PM
94m5's Avatar
Sorry About the long reply time. The 350 has never been bored or machined. It's out of a 75 4X4 im pretty sure. Im wanting to get an LT1 to build while I've got the money to throw in it. I've got 4 or 5 different small blocks and assorted big blocks from all of the big 3, but no LT1's.
Old Aug 7, 2003 | 11:49 PM
94m5's Avatar
P.S. the Power steering will need to be modified to fit. New custom lines will take care of it.
Old Aug 8, 2003 | 12:50 AM
FLIPPINZ28's Avatar
thanks for all the replies and help that power sterring question helped me out pretty well hey 94 m5 would you trade a big block for it
Old Aug 8, 2003 | 12:52 AM
RedPhenx's Avatar
this seems like a lot of work since you are just going to pull it anyway.... i would just not worry about it
94m5's Avatar
The big blocks are taken, Thats why I mentioned the small block. I am very interested in trading the two.
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Newgmman
Feb 25, 2015 02:53 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Lederman1976
Nov 30, 2014 05:21 AM
