How to remove EGR?
Old Aug 6, 2003 | 12:19 PM
mook99TA's Avatar
How to remove EGR?
How do you remove the EGR in our LS1?
Old Aug 6, 2003 | 12:53 PM
2001NBMZ28's Avatar
http://www.ls1camaro.net/sections.ph...icle&artid=70.
Old Aug 7, 2003 | 09:03 AM
Constrictor98TA's Avatar
Its simple. One 10mm bolt on the top of the intake, two 10mm bolts on the passenger side header, and 2 15mm bolts on the passenger side cylinder head. Unhook the electrical harness and throw away.
If you are keeping your stock intake, you'll need to plug the hole at the top of the intake with a freeze plug. Not sure which size. Or you could upgrade to an LS6 intake without EGR provision. You will also need an EGR blockoff plate for your passenger side header.
Boss002
Jan 20, 2016 12:17 PM
Jlo
Jul 29, 2015 03:52 PM
RX Speed Works
Jul 24, 2015 02:25 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
Jul 17, 2015 02:47 PM
