Wiring Help
Old Aug 5, 2003 | 09:41 PM
Green&Mean's Avatar
Wiring Help
Hi, I just purchased my 4th gen about 3 weeks ago and am trying to find where to run the power wire thru the fire wall to my amp, but I cant find the hole. I dont know if this makes any difference but my car is a 6-speed convertible. Also I am trying to mount the amp under the passenger seat but it wont fit, any ideas?
Thanks in advance!
Old Aug 5, 2003 | 11:22 PM
firebirdude's Avatar
Under the hood. Passenger side near the firewall. Remove two 10mm bolts holding in the PCM. Slide the PCM to the side. You can now access and grommit the will fit upto 1/0awg power wire. Good luck fitting anything under the seat.
Old Aug 5, 2003 | 11:36 PM
Green&Mean's Avatar
UMMMM? what is a PCM and what does it look like?
Old Aug 5, 2003 | 11:44 PM
It's your car's brain. Small 12"x12"x3" box. The bolts are facing up. Right at you. Can't miss em'.
Old Aug 6, 2003 | 06:24 AM
LS1 RULZ's Avatar
The PCM is right next to the hood's hinge on the passenger side.
If you have a Firebird you can use my rear wall amp rack. Click on "White Rascal" below to see all the details. If you have a Camaro you might be able to use the info there to come up with something for your car.
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Ryabut98
Sep 3, 2002 11:45 PM
kandied91z
Aug 6, 2002 01:18 AM
