Reprogramming new key fobs??
Old Aug 5, 2003 | 05:43 PM
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
Question Reprogramming new key fobs??
How do I do it??? After 5 years of abUSE my stock fob wasn't working too well.. I'd literally have to squeeze the **** out of it to make it work. So I finally got some new ones now and need to get them "programmed" for my car I guess? Anyone know how this is done?
TIA
Old Aug 20, 2003 | 08:37 PM
Mark W. Winning's Avatar
I found this a while back when I was looking for the same information. It worked fine for me. I wish I could give the original poster credit, but I lost who it was. Sorry.
Transmitter Programming
Important
All transmitters which are to be recognized by the body control module (BCM) must be programmed in a single programming sequence. If the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.
Turn the ignition switch to the OFF position.
Remove the RADIO (#17) fuse.
Cycle the ignition switch from the OFF position to the RUN position 3 times within 5 seconds. The BCM will confirm entry into the programming mode by performing the following actions:
Locking both of the doors.
Unlocking the driver's door.
Releasing the rear compartment lid.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter for approximately 15 seconds. The BCM will confirm the programming of that transmitter by performing the following actions:
Repeat the previous step to program up to 4transmitters.
Replace the RADIO (#17) fuse.
Operate the transmitter functions in order to verify correct system operation.
Document ID# 641006
2001 Pontiac Firebird
68camaroboltz
Oct 5, 2015 11:56 PM
colts0455
Oct 4, 2015 09:47 PM
colts0455
Sep 27, 2015 01:07 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
