Where to place O2 sensors?
Old Aug 5, 2003 | 05:37 PM
kevmor99's Avatar
I've got older SB manifolds and a complete custom exhaust, where should the O2 sensors be installed? I think I've heard to install them in a straight section (not near a curve), but how close to the manifold? If it isn't close enough, will they get hot enough or will the readings be off? Or is it not that critical?
Old Aug 5, 2003 | 06:04 PM
63SSRagtop's Avatar
From what i understand they should be within 12" of the head somewhere.. expecially if they are single wire non heated ones.. the 3 wire heated allows you to get them down in the collectors on headers as the hot wire will keep the sensor hot enough to get accuracte air/fuel ratio numbers for the ecm.. velocity of the exhaust probably does factor in but i think the operating temp is paramount over flow concerns.. course you didnt hear it from me..
Old Aug 5, 2003 | 06:40 PM
kevmor99's Avatar
Ok, do you have any pictures of your LT1 swap?
Victor Lamb
Aug 26, 2017 02:52 PM
Magenta_Hearts
Mar 29, 2017 08:54 PM
BigWil
Mar 29, 2015 12:24 PM
captcorvette
Mar 7, 2015 12:37 PM
