N2o plumbing help! quick!
Old Aug 5, 2003 | 05:13 PM
reuter's Avatar
hey im in the process of running my nitrous plumbing right now and was wondering how yall ran the nozzle into your intake elbow? i tried pokin a small hole in it and wiggled the nozzle into place but its flimsy. the hole is real small and closes itself back up shouldnt be a vacuum problem. someone please give me a suggestion quick so i can get back to work! thanks!
Old Aug 5, 2003 | 05:15 PM
JSK333's Avatar
Pull your IAT sensor/holder out and use the supplied nozzle nut to mount it in that hole. Then you can zip-tie the sensor to your noid lines, or relocate it to your filter.
Old Aug 5, 2003 | 07:06 PM
reuter's Avatar
good stuff
one more thing though, when im running my fuel supply line off the schrader valve, what do i do with the stuff that is already plugged in there? there are a couple things already in it and i dont want to just take them out. anybody?
Old Aug 5, 2003 | 07:36 PM
JSK333's Avatar
You have to remove the core from the valve, you don't have a choice. Use a simple tire stem valve removal tool. Then the line screws right on.
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
