Looking for tuner cat pro
Old Aug 5, 2003 | 05:08 PM
Schurters LT1's Avatar
looking to talk to someone about the program and wear to start with it,
My car is a 95 t/a heads and cam'ed car and ALL the outher bolt on's
thx
Old Aug 5, 2003 | 05:27 PM
conquest lt1's Avatar
doh!!!
www.tunercat.com
sheesh, have you ever heard of GOOGLE!
Old Aug 5, 2003 | 06:48 PM
iwon's Avatar
Originally posted by conquest lt1
doh!!!
www.tunercat.com
who the **** are you to talk to someone like that, not all of us are online all the time, sit down and shut you mouth newbie
Old Aug 5, 2003 | 08:26 PM
I am looking for someone who has been useing the softwear for a long time now and knows the in's and out's. So i can talk one on one to help me out.
Old Aug 5, 2003 | 09:26 PM
95Blackhawk's Avatar
Probably the best thing to do is find what you want to accomplish first. State this and we can start from there. Instead of having someone walk through every nuance of programming, my suggestion is to go step by step and use us on the board to help you along the way. There are plenty of us here that know as a whole a lot more than any one person and generally you will get plenty of help.
So again, what is it you need to accomplish?
Ben
Old Aug 6, 2003 | 04:35 PM
well what i am looking for is a insight into the program on where to start,
Parts list,
gm 847 cam
1.6 rr
advanced heads (full port)
e water pump
52mm tb
timing chain
m6
3.73 gears
1 3/4 rk sport headers off road pipe ,borla.
1-how do you clean up the idle
2-skip shift
3-gears
4-fans what temp both of them
5- + or - timing or fuel
6-anthing more ?
thx
Old Aug 7, 2003 | 08:34 AM
JAFO1994's Avatar
If you have any scans or logs from running the car that would help everyone out here also. So that they can view them.
There various ways to clean up idle;
timing
IAC counts
Are the BLM's split much at idle?
You may need your idle raised
Individual fuel trim at idle and so on
low vacuum?
Fans can be changed in your ECM constants table;
Fans on thresholds table
Once again a spreadsheet of your scans would be much needed.
Aug 24, 2015 06:41 AM
realistyc
Jul 28, 2015 07:32 PM
colts0455
Jul 24, 2015 04:51 PM
Boss002
Jul 9, 2015 03:33 PM
