F body experts needed on questions?
Old Aug 4, 2003 | 11:07 PM
kaoticcamaross's Avatar
I have 2 question about my car. Had it for about a year and a half and it's right at about 100,000 miles. I just added some stuff to the car but nothing to really make a difference in performance. Anyways it has started making a noise that sounds like it's coming from under neath the shifter when i hit the brakes or throw it in reverse. I have an automatic by the way. It sounds liek a popping with a rattling sound. Any suggestions on what it could be? Next I ran the car at the 1/8 mile track this weekend and it ran 9.3's. Is this good for a car that only has custom pcm tunning for the fan temp and shifting point that runs on 93 oct. and has a 160 thermostat with slp loudmouth? Just wondering and maybe you could give me an idea of what i would run based on that time in the 1/4. The car is basically stock.
Old Aug 5, 2003 | 01:27 AM
RedPhenx's Avatar
for your run... average is take 1/8 mile time and mulitply by 1.5
other question: I've never heard that sound.. sorry cant help you there
Old Aug 5, 2003 | 01:35 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: F body experts needed on questions?
auto or manual.
does it do it under load or when your shifting?
Old Aug 5, 2003 | 01:55 AM
Cmr0z28's Avatar
Old Aug 5, 2003 | 06:30 AM
Well thanks for the info on the 1/4 mile. That means i should be running like 13.9's on a basically stock lt1. Is that fast slow or average for an lt1? Oh and about the other question as i stated above it is an auto and it makes the sound under light braking and when kind of like riding the brake n reverse. Any idea yet?
Old Aug 5, 2003 | 08:34 AM
JKDZ28's Avatar
hows the trans mount?
Old Aug 5, 2003 | 05:40 PM
Ok stupid person here whats that mena to me
Old Aug 5, 2003 | 06:43 PM
RedPhenx's Avatar
transmission mount.. little thing at the end of the tranny. 13.9 is pretty decent for stock auto lt1
Old Aug 5, 2003 | 08:38 PM
Yes i can't figure out why it runs that good. I mena it has 2.73 gears. They said if i just changed the gears to 3.42's then I would be in the 8's for the 1/8 mile. The computer has the shift points set up kind of liek getting a shift kit but still i think thats good for no engine work.
Old Aug 5, 2003 | 08:56 PM
CoUnTryMuZiCZ28's Avatar
Check your cat... Mine made a loud sound after cat back install the noise started about 2 months after the catback install... all the stuff inside was loose.... gutted cat no more noise.
Old Aug 5, 2003 | 09:37 PM
hum good idea. I'll check that out when i get my headers installed. Only question is why would this only happen in reverse or breaking?
Old Aug 5, 2003 | 09:40 PM
I have no idea... The reverse problem is because your on the brake.... It only happend to me when i braked. Sounds like a bunch of metal bb's hitting a pan. I think its when the rpms drop, that makes it happen. but then again you dont really get to high in the rpms while reversing... i duno but that was what my problem was, only braking.
Old Aug 5, 2003 | 10:08 PM
ok that sound right to me. i'll get it checked out.
Old Aug 5, 2003 | 10:10 PM
Let me know if that was it.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Queens94z28
Dec 20, 2014 09:11 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
Brent94Z
Mar 21, 2002 04:44 PM
