How Do I Do a Compression Check?
Old Aug 4, 2003 | 02:16 PM
snorkelface's Avatar
Question How Do I Do a Compression Check?
How do I do a compression check on my '97 LT1?
If the compression check cmoes out OK, how can I verify if my timing chain just jumped some teeth?
Old Aug 4, 2003 | 05:08 PM
Compression test
Old Aug 4, 2003 | 05:23 PM
TexasTechTA's Avatar
remember to pull the Ignition fuse and the PCM BATT fuse I ruined an opti by not doing this on my comp test.
Old Aug 4, 2003 | 05:30 PM
I'll definitely do that, thanks!
If the pcm batt fuse is pulled, the coil will not fire, even it it has power.
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
