Can bad opti cause really bad low end hesitation?
Old Aug 4, 2003 | 11:38 AM
Shawn W's Avatar
Ok so here's the deal. The shop just finished putting my motor in my 94 Z28. Here is a list of the mods that were done at the time:
Eagle crank
Scat 4340 Rods
Speed Pro pistons
CC305 cam
Comp valve springs
Comp hardened pushrods/ Guide plate
Crane Gold Non- SA roller rockers
Lunati Timming set
Mac Headers
New plugs and wires.
Heres the problem. The car starts and idles fine. Whenever you drive it though it Runs pretty good untill it gets warmed up. After it gets warmed up it runs like absolute crap down low. Under 2500 RPM's it has no power and pops back through the intake. It doesn't do any of this when it's cold.
Is it the cam that is making it run ****ty? I am on the stock tune with stock injectors. Stock fuel pressure
Or is the opti crapping out when the car warms up? My Mechanic said the cap and rotor were good on tmy opti but couldn't verify for the rest.
I have no SES light either.
Tell me what you think.
Shawn
Old Aug 4, 2003 | 12:22 PM
97Z-M6's Avatar
is it still a 350 or is it a 383 or other if it is it may be to small injectors, and if the duty cycle is to high on the stock injectors it could be because of tuning. you need to get it scanned and check for codes the get the tunning done.
Old Aug 4, 2003 | 12:26 PM
Camaro_Maniac63's Avatar
I think you definitely need some tuning done on that car. I have the Hotcam in my car with the stock tuning, and my car pretty much does the same thing, although it is not as bad as what you are describing. Tuning does wonders for the lower RPM power, I have heard.
Old Aug 4, 2003 | 12:40 PM
Shawn W's Avatar
well i am waiting on PCMFORLESS to get here. I put in all the specs for my car. How much do you think that will help?
Also my car is a 355CI
they said they ran a scan on it and everything showed up normal
thanks
Shawn
Old Aug 4, 2003 | 12:48 PM
Tuning is a must for cars with different cams. Sometimes it gives you a lot of hp, sometimes it doesn't, but either way, it improves driveability a lot. I think with your setup, you might want to get it dyno tuned rather than mail-order tune. But then, I've heard Bryan does a great job. I hope he can hook you up and get you going nice and smooth. Nice combo you got in that car by the way. Good luck.
Old Aug 4, 2003 | 12:49 PM
94 Roadhog's Avatar
Yes!
Old Aug 4, 2003 | 01:08 PM
Shawn W's Avatar
thanks man, I would go ahead and get it dyno tuned but i still have heads and a higher stall converter to do. I am hoping the mail order tune will get me by for now. I have heard great things about PCMFORLESS. So you guys think it is more the tune than the Opti? I mean the Opti worked fine on my old engine and it didn't get any damage or anything while it was off.
I guess when the engine warms up and goes into closed loop the cam is just kicking the computers ***?? What do you guys think?
Thanks again
Shawn
Old Aug 4, 2003 | 01:34 PM
playaz28's Avatar
all my extensive limited experience tells me that it is your PCM that needs tuning.
Old Aug 4, 2003 | 02:22 PM
Fastbird93's Avatar
I had that exact same problem on my Black T/A about 3 years ago. Ran fine cold, but once it warmed up, started to miss, pop, hesitate, all below 2000-2500. It was the Opti.
CARiD
Jan 27, 2015 06:27 AM
Alex Barnes
Jan 24, 2015 10:21 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
IRABuss
Sep 7, 2011 09:08 PM
