Computers on a 1981?
Old Aug 2, 2003 | 10:52 AM
EmperorFuzzy's Avatar
Hello everyone,
I am in the process of restoring and modifying a 1981 Camaro. I recently read that the 1981 Camaros were the first ones that came from the factory with a computer.
My car doesn't have it's original engine; it was originally a 6 cylinder and a previous owner installed a 350. (Imagine that) The car has factory gauges, all of which work.
My question is, what exactly did the computer do, and am I going to run into any problems with my gauges functioning if I rip the computer and what wiring is still attatched to it? The mess of wires is rather unsightly and I'd like to get rid of every one I don't need.
Thanks a lot!
Brian
Old Aug 2, 2003 | 01:57 PM
BamaZ28's Avatar
I have a 1981 Firebird that originally had a 6 cylinder, but the switch to a SBC was made. As far as I know, 1981 did NOT have a computer to control the engine. 1982 was the beginning of all that. I have not seen any computer stuff on mine. You should be fine.
BamaZ28
Old Aug 2, 2003 | 08:15 PM
Erik's Avatar
Classic Tech Moderator
American 1981 camaros recieved a computer which controlled the carb mixture, check engine light and lock up torque converter (TH350C tranny).
Old Aug 3, 2003 | 04:57 AM
RedPhenx's Avatar
was for electronic carb... though I am not sure if the sixes had the 'commando' or not.
best bet would be to get a wiring kit so you dont have wires all over the place
Old Aug 6, 2003 | 10:33 PM
the spindoctor's Avatar
my '81 6cyl had a computer, but it would still run without it. it has an O2 sensor, and apparently it can make slight adjustments to that, but i think it's mostly at idle. the guages will work just fine.
http://www.nastyz28.com/camaro/camaro81.html
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
fireside286
Sep 15, 2015 10:11 PM
350350
14
Aug 11, 2015 12:03 PM
