Coolant Light is on for no reason!
Old Aug 2, 2003 | 02:40 AM
camaroman11's Avatar
It was a hot day and the low coolant light came on, and I filled it up more with some water but its still on. I even drained out the system and refilled it and its still on, I even tried to bleed the valves a little bit but still. It just came up about 2 weeks ago everything was fine since. But now the light is on and it feels like the car is heating up faster.
Old Aug 2, 2003 | 03:04 AM
m0nk's Avatar
Do you have an electric water pump, or is it stock. When the car is running is there water leaking? Might try seeing if there is water circulating into the radiator, **SLOWLY** remove the cap while the engine is running, and see if any water is being circulated back into the radiator, the hose is right on top.
Old Aug 2, 2003 | 03:09 AM
The waterpump has been replaced, but with the OEM part so its not the electric one, and it has been working fine. Yes while the engine is on the water is ciculating, the water rises and lowers and I can see water come out from a little hole inside (from the resevoir)
Old Aug 2, 2003 | 03:53 AM
96LT14u2Nv's Avatar
could just a be a bad sensor. it is a common problem in LT1's
Old Aug 2, 2003 | 06:32 AM
Derrick Redd's Avatar
Ditto. Change your low coolant sensor in front of the radiator. My car did the same thing and it was just the sensor.
Old Aug 2, 2003 | 06:41 AM
anasazi's Avatar
http://web.camaross.com/forums/searc...der=descending
Old Aug 10, 2003 | 03:27 PM
Ok im looking for that part on autozone, whats it called? can someone give me a link please??? I appreciate it thanks!
Old Aug 10, 2003 | 03:31 PM
anasazi's Avatar
Old Aug 10, 2003 | 03:32 PM
I tired clikin on that link before it doesnt work it says it invalid.
Old Aug 10, 2003 | 03:35 PM
anasazi's Avatar
low coolant sensor
Old Aug 10, 2003 | 03:38 PM
Search Results
Search Term: low coolant sensor
Searched: Entire Catalog
Sorry, there are no exact matches for your search term. Some possible matches are listed below.
PARTS
AIR CHARGE SENSOR
AIR CHARGE TEMPERATURE SENSOR
AIR CLEANER TEMPERATURE SENSOR
AIR FLOW SENSOR - MASS
ANTI-LOCK BRAKE SENSOR LEAD
BALL JOINT - LOWER
BAROMETRIC PRESSURE SENSOR
BELLOW - RACK & PINION
BLOWER CONTROL SWITCH
BLOWER MOTOR
BLOWER MOTOR WHEEL
BLOWER/HEATER SWITCH
CAMSHAFT POSITION SENSOR
COOLANT TEMPERATURE SENSOR
CRANKSHAFT POSITION SENSOR
DETONATION SENSOR
EGR POSITION SENSOR
EGR VALVE PRESSURE SENSOR
ENGINE TEMPERATURE SENSOR
GASKET - LOWER SET
captcorvette
Mar 7, 2015 12:37 PM
MattFick
Feb 15, 2015 10:16 PM
rwferguson43026
Feb 6, 2015 10:06 AM
NewsBot
Jan 21, 2015 04:00 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
