Will an LS1 fit??
Old Sep 14, 2002 | 02:28 PM
LanceJoker's Avatar
Post Will an LS1 fit??
I've put an LT1 into my V6.It's been a year now and I'm starting to realize how I wish I had tried to go with an LS1.So now I'm doing my homework.Will and LS1 fit into an LT1 Fbody with adjustments to the crossmember to accomodate the new engine??Thanks guys.
Lance Phillips
95 Camaro-Project Showcar
Old Sep 14, 2002 | 04:07 PM
zlightning's Avatar
Post
YES
Old Sep 14, 2002 | 04:39 PM
6speedZ28's Avatar
Post
You will need a different hood as the LS1 sits higher than an LT1 and the LT1 hood won't clear it. Good luck.
1998 Camaro SS A4 #2,515 OF 3017
NBM w/ grey leather
T-tops, all GM and SLP options
MODS:
-SLP dual-dual (came with car)
-Hypertech 160 thermo
-SLP Lid w/ K&N and smooth air bellows
**1997 Z28 M6...yes it was modded. Totalled by a girl who couldn't stop for a stop sign on 4-18-2002
Old Sep 19, 2002 | 10:40 PM
fbird95's Avatar
Up the stakes to an LT4 so in another year you wont feel the same way.
Old Sep 20, 2002 | 03:54 PM
CASPER97TA's Avatar
I have to agree. Go with the lt4. the iron block is gonna be a huge improvement if you plan on some serious power. i actualy thought the ls1 engine sat lower under the hood than the lt1. could be wrong
doug
Old Sep 20, 2002 | 11:48 PM
XKnightRider's Avatar
LT1, LS1, LT4....why not go big and get an LS6 !! I know a guy putting one in his '01 SS. Should be sweet.
But to answer your question, any of these engines will fit. But it's much easier just to go but the car you want.
Old Sep 21, 2002 | 11:52 AM
Jerm93z28's Avatar
unless you get a really good deal on a LS1, its not worth it. it would be soooo much easier to do a cam swap w/ headers on that LT1. that will by all means blow the doors off an LS1.
if it needs to be rebuilt, build it with nitrous pistons and run a 200 shot. shouldnt be too hard to get over 500rwhp with that setup.
doing a motor swap just for a stock LS1 is pretty goofy.... all that work for ~40rwhp is crazy.
jeremy
Old Sep 22, 2002 | 11:47 PM
2002Z28SSConv's Avatar
jeremy
True Dat!
Fastbird93
Apr 9, 2016 07:01 PM
Jun 6, 2015 08:27 AM
