WHAT REAR GEAR DOES MY CAR HAVE
Old Jul 30, 2003 | 06:54 PM
itchy's Avatar
Old Jul 30, 2003 | 07:04 PM
revtime's Avatar
If you can manually select 1st gear you have 3.23s
If on the other hand your selector only will let you go into second then you have 2.73s.
Old Jul 30, 2003 | 07:11 PM
itchy's Avatar
I FOUND ALOT OF THOSE CODE #'S
Old Jul 30, 2003 | 07:15 PM
Camaro_Maniac63's Avatar
Listen to what "revtime" said, that is the easiest way to figure them out.
Old Jul 30, 2003 | 07:18 PM
itchy's Avatar
HOW WOULD I NO IF IT'S 1ST OR 2ND
Old Jul 30, 2003 | 07:21 PM
You know when you are selecting gears, there is P,R,N,D etc.... In the same fashion, if there is a "1" in the same row with the P,R..... that you can select, then you have 3.23s. But if you don't have a "1" and have a "2" instead, you have 2.73s. Hope this helps.
1994CamaroZ28's Avatar
Should be extremly easy to figure out what gear your in, unless your a "moron" using the term lightly, Look on the gear selector on the console, if it has a 1 you have 3.23's.
Old Jul 30, 2003 | 07:22 PM
Zack's Avatar
is this guy for real?!
take a picture of your shifter, let us see it
Old Jul 30, 2003 | 07:24 PM
take it easy on him guys.
Old Jul 30, 2003 | 07:27 PM
itchy's Avatar
WHEN IT COMES TO CARS , GUESS U CAN CALL ME A MORON AND BE PRETTY ACCURATE. THE GEAR SHIFTER GOES LIKE THIS.
P
R
N
D
D
SO IF I HAVE 3.23'S IS IT WORTH GETTING 3.73'S
Old Jul 30, 2003 | 07:30 PM
Red96Lt1's Avatar
If it says:
P R D 3 2 1
You have 3:23's
If it says:
P R D 3 2
You have 2:71's
yes, you have 3.23s, and no, I wouldn't get 3.73s.
Old Jul 30, 2003 | 07:33 PM
itchy's Avatar
SO THEN MY NEXT MOD SHOULD BE HEADERS ???
Old Jul 30, 2003 | 07:37 PM
yes, headers are a very good idea. do a search on headers, and you can get an idea on what kind to get.
Old Jul 30, 2003 | 08:21 PM
Don't Look Back's Avatar
If the guy who had the car before him did the first gear bypass, chances are he didn't put in a shifter plate which says 1. The guy before me did the bypass on my car, but never replaced the shifter plate, so I pulled one out of a junkyard. Just look at the RPO codes in the box. It will be GU and a number.....
