Just scored a LT-1 4bolt block
Old Jul 26, 2003 | 10:00 PM
CoronaL's Avatar
scored a 4BM block off ebay for $149.99
prolly $50-75 to ship
opinions/options wanted about buildup of shortblock
Goal 400-425 RWHP
top end will consist of Lloyd elliot ported LT1 heads, cc306 cam, 1.6rr's, port matched intake. Most bolts on's.
either AS&M or Jet Hot LT's and off road pipe. Tuning by madwolf.
I will probably use these parts on my stock shortblock till it goes belly up.
Want some opinions on what you guys might do with this block etc..
Old Jul 26, 2003 | 10:56 PM
White96Z's Avatar
I am a fan of engines that are bored a bit, say a 355. I would keep it simple with some strong forged pistons with a little higher compression than a stocker. I would stay away from nitrous and superchargers. Not to say there's a thing wrong with them. It's just personal preference. Strong NA motors are a thing of beauty.
Old Jul 27, 2003 | 12:05 AM
madwolf's Avatar
John,
you willl most likely have to refreshen the walls. If the block that you got is from who I think it is, then you will definetely need it overbored.
Old Jul 27, 2003 | 12:43 AM
I don't think it would be worth it to simply "swap blocks" with your stock internals.... there is no benefit to the 4-bolt mains on anything under 500HP. The cost of freshening it up and changing everything out would not show any payback. Save it for a big buildup, with forged parts, and possible a major power adder.
Old Jul 27, 2003 | 02:55 PM
CoronaL's Avatar
here is the link ebay link for block
I was going to keep it, and in time get the work done. I am thinking I can get 2-3 years out of the shortblock that is in the car I bought.
Over this time I would prolly bore it 0.30 over and have it tanked etc....
what do you think
am I stupid for getting this
I figured I would like to have an extra block to start the buildup before I hosed my motor, then simply swap the heads/topend off the older motor and use on the new one eventually.
Old Jul 27, 2003 | 03:21 PM
DiabloZ's Avatar
I'm doing the same thing. I kept an extra block I had for myself to biuld up. I am going to make it into a 383. The engine in my car has a stock short block and that is holding up fine for now, but I want more and I'm sure I'll blow it apart sooner or later. This way I have plenty of time to build the new short block and I can watch for real deals since I'm in no hurry. I just had the block tanked and bored .030 and I had them put in the cam bearings for me. I'm all set to gather parts and assemble it at my liesher. O.K. I don't think I know how to spell liesher but anyway. This way you have plenty of time to decide what you want.
Old Jul 27, 2003 | 03:38 PM
SloMofo's Avatar
I have a spare stock 2 bolt Lt1 block on my porch. I will be using that for my 383. I plan to have the caps splayed
Old Jul 27, 2003 | 03:57 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
i agree with fred.
this sounds like a disaster
Why swap blocks? Lt1 blocks are good for a ton on power, most likely more than you could make. your crank will break before the caps will.
Old Jul 27, 2003 | 04:20 PM
Zjoker's Avatar
Is it an LT-1 or LT1 block? I once read an article stating the LT-1 was the first gen and the LT1 was the second gen. Just curtious if any body else ever heard that
Old Jul 27, 2003 | 04:48 PM
thewinner's Avatar
Good God you guys are picky at this guy. obviously he has an LT1 block from a corvette or a crate motor not the old Lt-1. Give him a break.
He's also not using his stock rotating assembly in it. Hes buying a top end and using it on the stock bottom end till it dies, then gonna build the 4 bolt block up....
Old Jul 27, 2003 | 08:51 PM
Josh-'04 GTO's Avatar
A standard 2-bolt block converted to splayed mains is stronger than the factory straight 4-bolt...just an FYI.
CoronaL's Avatar
yeah, it's a newer LT-1 not the early 70's block.
I guess I figured it was a descent buy and why not get a 4BM vs a 2BM for roughly the same price?
unless I'm gorked and 2BM are that much cheaper!!!!!!
Old Jul 27, 2003 | 08:56 PM
CoronaL's Avatar
And guys the point of this thread was to recommend shortblock buildup parts to make 425 or so RWHP which should be about 500-550 flywheel HP which if I'm not mistaken is pushing the limits of the stock crank and especially the rods.
I wanted opinions on good bang for the $$$ parts for the buildup once I can begin assembling the shortblock
thanks
i was never gonna stick stock junk in this
and yes maybe some day in 2-3 years I MIGHT go forced induction so yes I will used forged pistons and better rods and cranks, hence reason I wanted this 4BM block
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
heus
Sep 8, 2015 12:01 PM
