Pacific Alaska, California, Hawaii, Oregon and Washington
Who passes aircare?
Old Jul 26, 2003 | 08:41 PM
KrazyKamaro's Avatar
Who passes aircare?
Who passes aircare with there current setup? Also what are your specs, mods, HP/TQ, 1/4 mile time?
Old Jul 26, 2003 | 09:24 PM
talos's Avatar
hehe no way do i pass aircare, but i probably could with some tweaking.
my current setup is.
-1973 350ci 4bolt. !all emissions
-Holley 670cfm
-284-2H cam, 284intake 294exhaust (matching lifters/springs)
-2.5" true dual, 3" dual cutouts, 3" in/out 40series flowmasters.
-stock smoger heads
-Performer RPM Intake
-K&N
dunno bout the hp/tq yet, waiting to dyno.
1/4mile im guessing around low/mid 14s? i dunno
more mods but thats really only things that deal with the emissions for aircare
Old Jul 26, 2003 | 09:33 PM
So when do you get out of having to go through aircare? After your car is 25 years old??
Old Jul 26, 2003 | 10:05 PM
CoryM's Avatar
I passed this year. The car will never aircare again with this engine though. I just slipped through by the skin of my teeth. 377ci with camel hump heads and a little extra compression . I had to stick a leaned out Qjet on there and retard the timing to 4 degrees ATDC. Only emmisions is pcv. You still need to aircare all but collector cars. Have to aircare grandmas 74 formula 400. Although grandpas 64 falcon and model T dont need it.... I should ask why. Not sure if the firebird is a collector or not actually now that I think of it. Should be.
CoryM
Old Jul 26, 2003 | 11:12 PM
You can put collector plates on any car over 25 years old, providing that it is OEM. And you can put antique plates if it's over 50 years old I think. Not sure on that one though.
Edit: anything before 1970 doesn't have to go through aircare because it doesn't have any emission controls. Now thats the way to go!!
Old Jul 26, 2003 | 11:13 PM
talos's Avatar
something like that... but i do believe the car has to be stock
Old Jul 26, 2003 | 11:32 PM
raene's Avatar
I pass... after 8 tries
'88 CRX Si 1.6L SOHC engine (stock) swapped in favour of a JDM B16A 1.6L DOHC engine. Only mods are, cold air intake, exhaust system, B&M FPR, and an ACT clutch.
I don't really know why a 1.6L emits so much worse than another 1.6L but that's life I guess
Old Jul 27, 2003 | 01:17 AM
Erik's Avatar
Classic Tech Moderator
I've not even tried yet...
350, ~430hp
13.3@107. 2.3 60' thanks to a busted tach . It'll be a little faster on the 8th
I can't wait till 2006 when the aircare contract is up.
Old Jul 27, 2003 | 02:32 AM
oldschool's Avatar
I will...after a $1000 exhaust upgrade
Andy
Old Jul 27, 2003 | 02:44 AM
sleepybu's Avatar
and no aircair for farm trucks and vans
combo...81 malibu
9 to 1 355
xe268
rpm intake, not egr
700dp
long tube header,3" exhaust no cats
12.3s @ 113+ on radials
Old Jul 27, 2003 | 03:13 AM
bunker's Avatar
I passed with flying colors with mods in my sig!!!!!!!!! this is the big XE grind, biggest they really make beat that!!!!!
Old Jul 27, 2003 | 03:51 AM
JD30thZ28's Avatar
I passed fine with my mods below
Old Jul 27, 2003 | 04:04 AM
sleepybu's Avatar
the biggist xe cam i beleve is 250/256
what's your et
Old Jul 27, 2003 | 05:10 AM
sideways_Into_3rd's Avatar
the only way you would pass aircare is to get a mobile unit to come visit ur jackstand kingdom
and talos: sorry to burst ur bubble ... but i highly doubt low 14s out of that thing man . u need heads and gears... so go shopping already dont be a slacker
Old Jul 27, 2003 | 11:41 AM
Pandamonkey's Avatar
What about if a person were to drop a LS1 or LT1 in a 67 Camaro?
Would the same rule still apply?
