Any tricks to taking out the gauge cluster ??
Old Aug 29, 2002 | 04:00 PM
NEWBIE T/A's Avatar
Talking Any tricks to taking out the gauge cluster ??
I am gonna swap out the gauge cluster for another reman one - I have not been happy w/ the readings since I had the trip meter problem fixed.
(MY '99 specialty )
Anyway, I wondered if there were tricks I should be aware of - disconnect the battery, look out for it hanging up on this, here's how it is easiest to disconnect the wiring, etc. etc. !
Thanks !!
Britt
'99 T/A
Best 13.071 @ 104.92
Now own '99 SS # 2073 !
12.969 @ 105.44
[This message has been edited by NEWBIE T/A (edited August 29, 2002).]
Old Aug 29, 2002 | 05:26 PM
mvs's Avatar
mvs
Post
I just dropped you an email on the cluster removal process. You may want to have Autocraft (Harwin and Beltway - 713-981-5700) check out your cluster before you replace it.
Autocraft is a huge place that does authorized Delco repairs for speedometers. They may be able to check out your unit and calibrate it cheaper than getting a replacement.
Good luck.
manny
manny
'00 SS A4 Convertible
Old Aug 29, 2002 | 05:30 PM
NEWBIE T/A's Avatar
Thumbs up
<font face="Verdana, Arial" size="2">Originally posted by mvs:
Good luck.
manny
</font>
You hit the nail on the head w/ that one - I have been talking to Pat over there.
Even if the dealer was not interested in my complaints, Pat was - he says he would swap it out under warranty for $ 45.00 if he does the R & R - free if I do it !!
I figure I can pull a gauge cluster as well as the next man !!
I'll keep an eye out for that e-mail - it hasn't come thru just yet.
'Preciate it !!
Britt
Old Aug 29, 2002 | 05:54 PM
mvs's Avatar
mvs
Post
Pat also helped me out (lost the darn odometer reset rod). I keeping getting rejects on your email address (filtered???), so here goes my "throw down" instructions:
1. Remove the panel under the steering wheel ( 4 screws and two plastic push in screws)
2. Remove the “V” shaped bracket under the steering column (2 nuts)
3. Remove the 2 nuts holding the steering column. The steering column will now easily lower a few inches
4. Tilt the wheel down and remove the tilt lever
5. Remove the 2 screws holding the black plastic around the instruments and pull out the entire piece.
6. Remove the 4 screws holding the instrument cluster
7. Pull out the cluster and tilt the cluster a bit when you are taking it out.
manny
BinkZ28
Apr 20, 2015 09:10 PM
mattstrike
Mar 11, 2015 07:33 PM
94Camaro
Feb 28, 2015 03:00 PM
Joes96z
Dec 13, 2014 07:48 PM
CaRParts102
Dec 6, 2014 08:45 AM
