Maxed Maf?
Old Jul 23, 2003 | 11:16 AM
94 NO TOP Z's Avatar
Maxed Maf?
Is there an upper limit value you can put in the PE table? My MAF maxes out about 4800rpm and I gradually increase the PE above that.. seems like I have about 30% in there now at 6000. Just wondering how high of a number you could actually put in there.
Old Jul 23, 2003 | 02:39 PM
Sean94Z's Avatar
Not sure what the max # you can put in the PE tables is, but, it's my understanding that your MAF isn't even used when you're in Power Enrichment mode..
--Sean
Old Jul 23, 2003 | 10:30 PM
Chris B's Avatar
49.6 is the largest value you can enter (a function of the scaling factor the pcm uses). You can get around this by then increasing the coolant PE table to offset your entire curve and bring you back "in range".
The MAF is definitely used in WOT/PE mode - the PE table enriches the target a/f ratio, but the reading from the maf is used for base fueling to reach the target a/f ratio.
Now if you have a blower car you can easily max out the maf and then it really isn't doing much - but it is still used, you are just out of the calibration/input window.
Chris
Old Jul 24, 2003 | 07:12 AM
I'm going to put a higher value in there. I just didn't know if you accept a value that high or the computer would ignore it.
Thanks!
Double aught
Oct 2, 2015 11:29 PM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
