Tires
The 255/40 is going to be a skinnier than the 275/40. Also the 255 will be lower profile meaning the sidewall will be shorter. Depends on where you get the tires. I would actually recommend both if you could. Get the 275s for the rear tires and put 255s on your front tires. You want wider tires in the back for better traction, and skinnier tires up front b/c wide front tires cause problems with bumps, steering alignment and such and it becomes a hassle.
Re: Tires
Originally posted by CHRISCAMARO
What is the difference between 255/40/zr17 and 275/40/zr17 tires? What do you guys recommend.
I currently have the stock 16" on
thanks!
thanks!
Adam
Originally posted by SFB767
If he stated both are 40, the sidewall should be the same height.
If you do this, you won't be able to rotate your tires.
So, Vettes have 17s in front and 18s in back. They cant rotate them either.
