94 z28 rear end noise (bumps in driveline slack)
Old Jul 22, 2003 | 03:26 PM
drbling's Avatar
Question 94 z28 rear end noise (bumps in driveline slack)
Anyone had any experience with 1994 z28 rear end noise? The driveline seems to have some backlash (slop) and there is a noticible bumping sound under normal acceleration. It developed gradually, but continues to get worse. Is it more likely U joints or the gears? The car has 155k on it and still runs fine, no warning lights, etc. Thanks in advance.
mcj@hiwaay.net
Old Jul 23, 2003 | 02:29 AM
cals400ex's Avatar
you may have a different problem but several people have worn out rear lower control arm bushings. when going over bumps, the rear may screech or clunk. i think most of the time, the problem is worse in the colder weather.
Old Jul 23, 2003 | 03:46 AM
JWBerk94Z's Avatar
Also, check your torque arm. Be sure both bolts are still there on the rear end housing and that the rubber bushing on the tranny end isn't worn out.
Both of these things caused similar noises in my old 3rd gen.
Old Jul 23, 2003 | 07:48 AM
akrott1's Avatar
Re: 94 z28 rear end noise (bumps in driveline slack)
mcj@hiwaay.net
I had what I have heard called rear end chatter, but I never experienced it under acceleration....usually only when in reverse at idle speeds, I would get some loud clunking in the rear end. I fixed my pinion seal leak and changed the rear diff fluid and everything seems good now. I was sure that it was my u-joints, but the guy at the shop said they looked good, so it must have been just the rear diff protesting the crap gear lube that was in there.
oldschool
Feb 9, 2016 09:21 PM
Collector Car
Jan 5, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ModdedNerd
Dec 25, 2014 05:51 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
