Small leak
Old Jul 22, 2003 | 03:17 PM
tfs95z28's Avatar
Small leak
I was changin the oil today and noticed a small leak where the transmission connects to the driveshaft. Is this a bad U-joint or do I have another problem? The little bit of tranny fluid that was on the ground was not much at all, when i got under the car in that area i saw some seeping in that area around that connection. Any input on what I can do to stop it before it gets to be bad??? Also, if i run my car at the track, am i risking messing up the trans and/or driveshaft? I would appreciate any help that can be offered...thanks.
Old Jul 22, 2003 | 03:19 PM
KCFormula's Avatar
That sounds like your tailshaft seal for the tranny. I am pretty sure you can change it by taking off the driveshaft and pulling it out with your finger. Then put a new one in the opposite way.
Old Jul 22, 2003 | 03:22 PM
burnemonm1's Avatar
rear trans seal a task to do with your hand but its not a big job done it on my truck and my monte
Old Jul 22, 2003 | 04:01 PM
btchincamaro's Avatar
I doubt you're gonna pull it out with your fingers, its a little tighter of a fit than that, but its a simple job regardless. A small screw driver and a rubber mallot will do just fine.
Old Jul 23, 2003 | 12:46 AM
tfs95z28's Avatar
Thanks guys...figured it would probably be an easy fix. Didnt think it would be that big of a deal, I have heard that this is pretty common on f-bodies.
jwade88
Jun 14, 2015 09:38 PM
emailname
Jun 14, 2015 03:14 PM
Nellsw88
May 26, 2015 05:55 AM
Brake_L8
Jan 20, 2015 09:44 AM
