Amp rack/box help!
Old Jul 22, 2003 | 12:45 AM
stang_killa94's Avatar
Amp rack/box help!
ok so here is my problem http://community.webshots.com/s/imag...4RbgSpN_ph.jpg
as you can see its not the cleanest install ever...now what i was planning on doing building a simple box covering the amps but i was told that if i do that the amps wont get enough air and they will over heat. So what else can i do that will help hide those nasty wires without getting to custom? Or was i fed a lie about the amps over heating?
Old Jul 22, 2003 | 12:49 AM
<img src= http://community.webshots.com/s/imag...4RbgSpN_ph.jpg>
Old Jul 22, 2003 | 12:51 AM
just go here.......MAN i hate webshots is there any other website where i can upload my images?http://community.webshots.com/user/stangkilla94
Old Jul 22, 2003 | 01:31 PM
iamsparc's Avatar
do box and just put some fans in for ventilation.
Old Jul 22, 2003 | 03:46 PM
firebirdude's Avatar
Just lay a piece of 1/2" MDF over the amps, cut two squares the size of each amp and bingo. The wires will be covered, but the heatsinks on the amps will still be out in open air...... so to speak.
Old Jul 23, 2003 | 08:55 AM
LWillmann's Avatar
You could build a raised panel (1/2 inch or so above "hump"), mount everything to that and run the wires under it. Drill holes in it and push the wires up. You could carpet it to match the interior too.
Or, you can get crazy like I did and build an amp rack with fans and a glass top... Link to my cardomain page is in my sig.
RUENUF
Mar 13, 2016 03:37 PM
HibachiZ28
Nov 6, 2015 12:53 AM
Bobczar
Oct 23, 2015 11:22 AM
secbase8
Parts Wanted
Sep 8, 2015 07:11 PM
NewsBot
Jan 8, 2015 11:29 PM
