Advice needed....Should i get gears(4:10/3:73), or will i break them??
I have a 97 ss that dynoed 310 rwhp and 325 ft/tq....I also have 17x11inch rims in the back with 315/35/17 nitto DRs in the back...lots-O-traction.....
I have been told that if i get gears sucks as 4.10s or 3.73s the pinoin is much smaller and thus i will break it much easyer.
What do you guys think??? if i got 4.10 would i break them?? i ask cuz i am on a very limited budjet and would nopt be about to replace them if i broke them. thanx
Kenney DeRamus
'97 30th SS, M6 Hardtop
1.6 RR OBD1 conversion,LT1 edit expert eddition, LT4 KM
K&N Intake, MAC Headers with offroad Y-pipe, Flowmaster 40
LS1 Brakes, Eibach Pro springs, BMR Sway bars 32mm and 21mm, BMR STB, BMR subframe conectors, BMR control arms, BMR Bolt-in LCA relocators, BMR Panhard rod
SPEC stage 2 clutch, Throtel body bypass, Airfoil, 8.8mm wires
2 12in JL subs with 2 PPI 2100 amps
my new site: http://www.geocities.com/camarossguy2/CamaroSSguy2.html
Kenney DeRamus
if you drag race you will break the 4.10's if you dont do any drag racing dont worry about it. the 3.73's will be stronger but there is still a chance of breaking it. the only solution is a 12 bolt or hold off on the gears.
2000 black WS6 6speed
318 RWHP 322 RWTQ stock
best et: 12.72 with the et streets. 60' 1.81
bestmph: 109.72 first time out, no mods, on the street tires
Mods: centerforce dual friction clutch, moser 12 bolt w/4.10's
BFG dragradials, PRO 5.0 shifter
whats next: put the borla on, take baffles out of WS6 hood, tb bypass, et streets
wytblur
Aug 5, 2002 02:03 PM
