Ok my car has some serious problems
Old Jul 19, 2003 | 09:55 AM
95_RipperZ's Avatar
Installed a CC306, 1.6 RRs, electric WP, double roller timing chain, new valve springs, new rocekr studs, hardened pushrods, and PCM4Less programming.
Car has now killed 3 coils. one after market, put the stocker in and then installed the program, then a brand new one from auto zone. Car starts right up when I put a new coil in. I checked all connections and they seem fine. Car starts and runs for 2 days then I come out on the third day and it just wont start. It cranks and that is it. Keeping my car running seems most important and then I can figure out the following.
Then I get 9 degrees knock at idle, 6 at WOT. Maybe I need to readjust my RRs? The car doesn't run all that great on the street either. Under WOT from under 50 it doesnt seem to pull hard at all compared to prior to cam install. After 50 seems normal. That is for all rpms. I have a small fuel leak from where my SFCs were welded on too. Don't know what that would cause. I am going to look at it today. Any suggestions on it?
I get 2 codes, 33 (low vacuum) and now 41 (ignition, open) and here are my scanmaster readings which I can make little or sense of even using Fred's explanations. These are at idle, I just grabbed most stuff that I felt could be relevant.
MAF- 9 to 12
SP- 24-26
Lp-3.1 to 3.6
Rp-2.6 to 2.8
lbl-158
rbl-128
cel-16
Lin-128
rin-128
o2l-jumping 800 consistent at semi throttle
02r- same
ats-73
clt-101
tps-.64
tpp-0
iac-132
map-20 to 27
acp-.02
ccp-0
Old Jul 19, 2003 | 09:59 AM
joeSS97's Avatar
Well,I told you this before.Your rockers are too tight,causing low vacuum.And poor performance.What did you gap the plugs at?
Old Jul 19, 2003 | 10:00 AM
WayneE's Avatar
Re: Ok my car has some serious problems
When you installed the double roller chain, did you clearance the inside of the timing cover? Are you using an LT4 knock module?
I'm using a CC306 and it's low end is horrible... it really screams on the top end, though. I'd work on your other issues before worrying about power. That fuel leak is dangerous. Don't drive the car until you fix it.
Old Jul 19, 2003 | 10:03 AM
95_RipperZ's Avatar
Ya I figure that is part of the reason. I actually started adjusting them today. Got the valve covers off now. What is killing my coils though?
Old Jul 19, 2003 | 10:06 AM
95_RipperZ's Avatar
Re: Re: Ok my car has some serious problems
[/b]
I'm using a CC306 and it's low end is horrible... it really screams on the top end, though. I'd work on your other issues before worrying about power. That fuel leak is dangerous. Don't drive the car until you fix it. [/B]
I didn't clearance the timing cover. I was told I would be fine. That might be causing my knock huh. Would it kill coils though? How do I clearance it? I am using an LT4 KM too.
The car won't be driven again for sure until the fuel leak is fixed.
Old Jul 19, 2003 | 12:44 PM
WayneE's Avatar
Re: Re: Re: Ok my car has some serious problems
If it was rubbing, you should hear it. I've only installed 2 sets in cars, but both times we had to do a good deal of grinding on the inside of the timing cover.
No. You have other issues with the coils.
A grinder (faster) or file (slow).
Good. We don't want to hear about your car-b-q
LeftoverChinese
Jan 14, 2024 03:03 PM
jayblev95
Dec 1, 2014 06:55 AM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
