What would turn engine oil milky?
Old Jul 18, 2003 | 12:27 AM
neil350's Avatar
No sighns of coolant lost which looks real good, no oil in it. But the engine oil looks very milky.
Neil
Old Jul 18, 2003 | 12:29 AM
Dan95TA's Avatar
has the car sat around for awhile? When I put my t/a away for the winter and change the oil come spring it is usually milky or muddy looking. I can only assume it's from condensation because with the next oil change it's normal.
Old Jul 18, 2003 | 12:33 AM
neil350's Avatar
Its actually a friends car, the motor is brand new and the car is daily driven.
Old Jul 18, 2003 | 12:50 AM
terlox's Avatar
Since car and motorcycle oil are pretty damn close I'll throw in my .02. When I rebuilt my engine on my old bike I filled her up with brand new synthetic oil. I checked the little window to tell me what the oil level was at, and you could see it looked somewhat milky. After I ran it for a few days it faded to the dirty brown liquidy stuff we're all so accustomed to working with.
I think it's somewhat normal.
Old Jul 18, 2003 | 12:57 AM
SloLt1Z's Avatar
Hate to say it, but as I was told milky oil is almost always coolant. Hope it turns out to be nothing serious though
Old Jul 18, 2003 | 02:30 AM
unTAmedLS1's Avatar
heres what ya do pull valve covers off. If theres alot of yellowish milky oil stuck in em my best guess you would have a blown headgasket. Oil will always be milky with one so I would check that out first.
Old Jul 18, 2003 | 03:31 AM
Patman's Avatar
I don't think it takes very much coolant to turn your oil milky, so it's still possibly coolant. I'd highly suggest that your friend take a sample of that oil and send it in for analysis as they could tell him for sure if it's coolant.
Old Jul 18, 2003 | 03:41 AM
camaronutt's Avatar
Couldn't you just do a compression check to see if its the head gasket? That is where I would start, or just change the oil and see if it happens again. Be sure to change the filter too, for it may have coolant deposits in it, if that's even what it is. I have never changed my oil and had milky oil. The only time I did is when my S-10 scattered the #5 piston at 6000 rpm. It cracked the cylinder wall into the waterjacket, and leaked what wasn't burned into the oil. Good luck to your freind though.
Old Jul 18, 2003 | 06:26 AM
revtime's Avatar
My Dad cracked the block in one of his old pickups and the oil was really milky. I am not saying you have a cracked block but it is definately coolant.
My Dad was in denial, I said "Dad, its toast" and he said "but its holding good milk pressure"
Old Jul 18, 2003 | 08:28 AM
LPerry's Avatar
in my experience it has always been coolant or water. If you wanna know what it should look like dump a little used oil and coolant/water in a pan and leave it a few days. the bottom of one of my drain pans is milky from mixed use. if it is coolant it will be gunked all over the engine internals, pull a valve cover like someone suggested and take a look, if your scooping out milky oil then you'll know. Be careful, too much water will ruin main and rod bearings from loss of oil viscosity.
a bad head gasket will not always cause burning oil or oil in coolant. I just changed one where the only symptom was blowing water out the overflow.
Perry
Old Jul 18, 2003 | 08:37 AM
Oil+water = "milk".
HectorM52
Jul 30, 2017 11:46 AM
CaRParts102
Dec 6, 2014 08:45 AM
Jul 4, 2005 05:00 PM
formula79
26
Aug 5, 2002 12:21 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
