How to change gauge bulbs
Old Jul 14, 2003 | 09:15 PM
MAROSS's Avatar
How do i change the bulbs in the gauges to change the backlight color. I want it to be red. Where do i get the lights and any other advice.
Old Jul 15, 2003 | 09:16 AM
ExMustangOwner's Avatar
The bulbs area size 194 I beleive. The really small looking ones that go in your rear view lamps. You'll need 9 I think? You take off the two screws near the top of the housing that goes around the gauges and pull it away. There's 4 screws around the plastic shielding and it'll pull off. Then pull on the whole gauges cluster straigt out and it'll come off. ON the back you'll see these little rectangle *****. There's a bulb behind each one. Twist the rectangle part and change the bulb. Repeat the process and you're done. That's what I remember. It's been a while. Have a few extra bulbs in case I was short a few. Hope that helps.
Old Jul 15, 2003 | 10:42 AM
m0nk's Avatar
MAROSS your PM mailbox is full so I cannot send you anymore PM's, I sent you an e-mail regarding the muffler and when it would be convienent for me to pick it up. I work nights so hopefully days are available.
DirtyDaveW
Dec 1, 2016 05:37 PM
armedtrigger
Feb 24, 2015 08:30 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
jj71787
Jan 31, 2015 10:20 PM
